what is everyone doing for a rear trans seal on a 71 1200? 4sp
I think I found a stock seal in Missouri. Is there another seal that can be used?
thanks, John
Transmission rear seal
johnzracer
- Cars: 76 V8 powered Zcar
74 V8 powered Zcar(race car)
72 SR20DET powered 510
71 Datsun 1200
80 Datsun 310 race car
Re: Transmission rear seal
RockAuto lists 3.
The rear seal should work from.a 4 speed b210 (74-78) and a b310 (79-83) 4 speed.
Some 5 speeds should be the same also, but may just cause confusion.
Nissan Part# C2136-G1001, is available at the dealer- Gladstone Nissan OR NissanPartsZone.com lists for 10.04 + shipping
Gladstone Nissan is the only local dealer that will get older Datsun parts WHEN available,- sometimes they are Back Ordered to Japan and it may take a couple of weeks.
Morrisun
Morrisun
