Looking for the following for my 1200,
Brake proportioning valve and the 2 lines that got from it to the master cylinder.
Mark
WTB: 1200 brake parts
Re: WTB: 1200 brake parts
I MAY have the proportioning valve, not sure about having either of the brake lines, they are slightly different between the Tokico and the Nibco master cylinders. Parts are in storage- it would be 4-5 days before I get backup there. You may want to check with Randy in Citrus Heights, CA he has some 1200 parts left- it would be closer for you.
- Cars: 66' SPL311
- Has thanked: 25 times
- Been thanked: 109 times
I did email him a while back and I don't think he had them, or wanted more than I wanted to spend at that point. Don't remember. I'm in no big rush for the parts as I am still working on a motor swap. I have to dig the master out, but IIRC it was a Tokiko.
I found what you are looking for- I think??
Valve and lines have been cleaned up externally, however valve should be disassembled and cleaned!
