Today I had to fix the exhaust. Found out my hole was a rip where there used to be a hanger. I went climbing through some snow piles the other day, I'm guess I loosened something. Heard a pitch change yesterday, found that hole. Fortunately I had some scrap hanger material. Please excuse the pig's breakfast welding. That's what happens when you're on your back on a creeper with very little space between you and the work. The next house will SO have a lift. Anyway, no leaks now, then went and installed the new 9003 conversion lights. Much brighter, much better. And easy bulb replacement! We started carrying these at NAPA from Trucklite. Aluminum housing, glass lens. They seem to be pretty decent. Aligned them pretty well, will test again tonight when it's easier to see where the pattern falls. Garage cement pad before door isn't exactly level.
