The first one I had built was made out of a late Z22E with EFI block from a car, and it turned out great, everything looked normal when I put it together.
Today I went and picked up the second one that I am in the process of building and the pistons on this one don't come all the way up to the deck of the block like the first one I had built did, they come up about 3mm short, I am a little worried now about my compression ratio.
So I started looking into why the two block builds would be different and I went to the Jason Grey info on Ratsun and found this below, what may have happened is that the first block I built was a late Z22E with the 149.5mm rods, and this block was a Z22S with the 145.9mm rods, so this seems to me to be a problem, or my first block I built doesn't have 8.9 to 1 CR I thought it had, it is likely higher, maybe a lot higher.
Connecting rods
Center to center length, all use the same 21mm diameter piston wristpin.
L18, L28, L26--------------130.2mm
L16, L24---------------------133.0mm
L13----------------------------139.9mm
L20B, Z22S, early Z22E-145.9mm*
Z20S,- ------------------------??**
Late Z22E-------------------149.5m*
Z20E--------------------------152.5mm
Z24, KA24-------------------165.0mm
Does anyone know what the compression ratio will be on this block with a closed chamber head?
EDIT
So I figured this out, all is good!!!
