L block EFI on ebay
L block EFI on ebay
Get a look at this, don't see this come up very often, to bad about it's location.
http://www.ebay.com/itm/Datsun-L4-Fuel- ... 79&vxp=mtr
Re: L block EFI
Thankyou for putting this where it belonged.
Looks like the only thing missing in that package is the ECU and wiring, which the early 200SX stuff would work I believe.
Re: L block EFI on ebay
Will this work on an L16 I wonder?
Probably depends on what ECU and wiring are used I'm guessing.
It's for an L4, that's what an L16 is, might need different injectors, and the head will have to be modified for the injectors.draker » Sun Jun 29, 2014 11:00 pm wrote:Will this work on an L16 I wonder?
There is another one located in the USA, but it is just the EFI manifold/throttle body.
http://www.ebay.com/itm/Factory-Datsun- ... eb&vxp=mtr
Nissan ECUs only measure Volume of air in, air temp, and 02 readings. It should work regardless. Fuel mapping may be a bit off, but since a L16 will pull in less air than a L20b, less fuel should go in...
Fuel mapping would be off. You could lean it a bit by adjusting the MAF, but it would certainly run rich with the 200sx ecu. I've talked this over with Kelvin before.Laecaon » Sun Jun 29, 2014 11:46 pm wrote:Nissan ECUs only measure Volume of air in, air temp, and 02 readings. It should work regardless. Fuel mapping may be a bit off, but since a L16 will pull in less air than a L20b, less fuel should go in...
At that point, why not just run a KA? Cause price wise, your in the same boat.
Other than nostalgia.Laecaon » Mon Jun 30, 2014 2:35 pm wrote:Cuz some like l series...
also buying that manifold alone you aren't on the same boat.
