The "Retired" 510
Re: The "Retired" 510
#161
Does your 4-speed have a big steel pan on the bottom (510/521 style) or a small steel cover on the top with 6 bolts just ahead of the shifter (240Z style)?
noflers
Has thanked: 5 times
Been thanked: 22 times
#162
Post by noflers »
It's the 510 style.
#163
Sorry, shifter won't work on the 5-speed.
noflers
#164
Post by noflers »
So I've got all these new parts here, but none of the bolts. I should be picking them up Friday from the dealership, including the starter, bell housing, flywheel, pressure plate, and valve cover bolts. I wanted a throttle cable too, but they want $95 for it! Image
Until then, I'm stuck. I guess I could pull my motor and drop it in the 620 but I was hoping my buddy would get the engine bay cleaned up first. Slow bastard he is.
Indy510
Has thanked: 27 times
Been thanked: 132 times
#165
Post by Indy510 »
I just got a brand new Pioneer 240sx throttle cable, for a 1991 KA24DE, off rock auto for $32 ... and there's even %5 off discount codes in the Ratsun classified "discussion" forum
the cable is listed under "interior" on rock auto, and it looks really good .... I can take some pics if you want
#166
What are your crossmember plans?
noflers
#167
Post by noflers »
I saw those throttle cables, but wasn't sure about quality. I think I'll order one now.
I plan on the standard cross member flip. I'd rather not, but unless I can find one already flipped, or a custom pan/sway bar at a reasonable price, it's all I can do. I really just need someone to cut it straight for me, as I can weld it myself.
noflers
#168
Post by noflers »
How did you attach the cable to your pedal?
Indy510
#169
Post by Indy510 »
I'm using a 1991 240sx stock gas pedal ... it will take a little modification to fit a 510, but it would probably work. I got it for $30 shipped off ebay. My old cable was cut and threaded through a hole drilled in the top of the stock pedal, but the cable got frayed and turned into 100 loose strands.
#170
Don't mind me, just came by to check out the awesome car.
#171
Get creative and cut it with an angle grinder. Just dont forget to tack the ends of the crossmember together to keep their alignment.
And nice tip on the cable Indy! I need one too.
noflers
#172
Post by noflers »
I shouldn't be worried about making sure both cuts are symmetrical?
At first I was mad I had to spend $40 on a Helicoil kit, then I was actually glad I did because I've had to use three inserts so far, but then I was mad again when I remembered the PO stripped the bolt holes in the first place. At least they were all the same size (M6x1.0), so I only had to buy the one kit.
NOTE: Heli Coils are freakin' handy and easy to use, I think I'll strip more bolts!
I've still just been bolting things back onto the motor, I should have a finished picture later, just need to get the clutch on. Found one of the mounting ears on the starter is broken off too, so I'll need one of those... So far I've replaced, the rear main oil seal, CLEANED, removed upper timing chain guides, replaced most of the engine sensors, single belt/PS pump delete mod, CLEANED, new flywheel with new bolts, EGR delete, liquid gasket everywhere it needs to be. Oh, and I also cleaned and replaced the seals on the transmission.
P.S: New flywheel didn't come with dowel pins, and the motor didn't come with a flywheel so I can't take them off that. Most people will say they aren't critical, but what do you guys think? Bolt the clutch on, or wait and make the trek to the dealer again?
#173
I like the dowel pins...
As far as crossmember cutting. You can make it fairly straight. Use a laser guide to draw straight lines to cut on. Use a tape measure to make it fairly parallel.
If you mess it up too badly, just box in the end pieces and run some DOM in place of the cut out piece.
noflers
#174
Post by noflers »
Do you know the wall thickness of the crossmember material by chance?
#175
Page 13 of this:
https://drive.google.com/file/d/0ByCvxn ... sp=sharing
Updated crossmembers have a thicker bottom plate as explained in that pdf. I would imagine the rest of the crossmember is the same as the old bottom thickness.
#176
And I suppose it would be good to share where I got that from...
https://drive.google.com/drive/folders/ ... sp=sharing
noflers
#177
Post by noflers »
Great info, thanks.
Here's this:
Still waiting on bellhousing bolts so I can stick the trans and motor together...
Btw, Subaru exhaust manifold studs work great for the KA!
#178
Since Subi is Fuji Heavy Industries which Nissan used to own a big part of, there are a lot of things that make too much sense.
noflers
#179
Post by noflers »
You know, now that I think about it, the exhaust downpipe flange is the exact same too
#180
Well, huh. Never even considered the crossover with Fuji.
