Currently, the rear suspension has 6.5" ground clearance, and the front has 4.25" ground clearance (measuring to the suspension crossmembers). I want the front to be lifted to about even with the rear, maybe half an inch lower.
Does anyone have the stock front spring dimensions? I'd like to compare and see what kind of lift the springs I have might provide.
Insert Info:
BZ3038 gas cartridge illumina adjustable-5 Tokico
Strut Tube Info:
54302 A3050 kyb
Coil Spring Info (Small Blue):
OD= 9cm
ID= 6.75cm
Length= 22cm
Coil Spring Info (Big Blue):
OD= 13cm
ID= 11.5cm
Length= 32cm
I'm not sure what exactly the front suspension consists of right now, but if I had to guess I'd say stock struts with cut springs. Also, there's a nice hack job of the strut mounts.
