Found a piece to my coolant system I forgot I had. This piece runs under the intake manifold and returns coolant to the waterpump.
On the left is the Heater return (lines up just about perfect with the cars heater), next is the back of the intake manifold (I think its turbo return) and its getting deleted. Then the next small line on top is Throttle body return (deleted), the bigger one at the same spot is connected to the thermostat housing (pre thermostat), and it has a small line off of it for feeding the throttle body(small line getting deleted). Big hose one right is radiator return.
I also picked up a set of ZX steering knuckles (info in insomniacs...)
And I also ordered some hole saws to finish up my axle conversion.
