-Will a 75 710 wagon ignition switch fit a 74 710 hardtop?
-Will 74 hardtop rear leaf springs bolt to a 75 wagon? .. the shocks look different, so I'm assuming I'd need to swap the parts that hold the leafs to the shocks.
-Are all 710/711 H165 rear axle assemblies the same? .. with the same leaf mounts?
-Will any 710/711 driveshaft fit any 710/711 with the same motor/trans combo? i.e. can my wagon's KA swap bolt into a 74 hardtop, without needing a new driveshaft or tranny mount?
-Do all 710/711's have the same front suspension, cross-members, and T/C rod mounts?
-Asside from the starter wiring being different, what are the differences between 74 710 wiring and 75 710 wiring harnesses?
-Will 75 wagon park bench bumpers fit on a 74 hardtop? The front is probably the same, but I doubt the rear is.
First person to answer one question correctly, gets a picture of my new 74 710 hardtop ...
