draker wrote:At what point does brap brap happen?izzo wrote:So... New head gasket, new intake exhaust gasket. Got all the parts swapped over, dizzy, alternator, auto line holders etc.
To do list
Fuel line from tank to pump needs hooked up.
tighten down driver side motor mount.
Put the little line holders back on the auto lines to radiator.
Install radiator.
Drain oil put fresh in.
Top off oil & coolant.
Give her a test fire!
Then I need to time it, and need to heat her up and hot set the valves.
Was hoping tonight. May look like tomorrow. Nobody has the effing water pump gasket in stock. FUCKING christ. I hate getting up at 5am to give the GF a ride to work.
