Adam's annoying ass green 620
- Eagle_Adam
Been on vacation....
- Eagle_Adam
I dropped the newest cyl head off at my
Machinist to get the threads repaired!!! Once it's back it should be game on finally !!!!!
Nice!
Dude who had the KA wanted to know if I had it in my car yet...
- Eagle_Adam
Before:
After:
Once I get back from vacation I'll install the head and cams for what I hope to be the last time
After:
This feels like it's taking forever.
- Eagle_Adam
Yup, first one in years
- Eagle_Adam
on a progressive note!
im back to ordering parts and thinking about my build.
Picked up a new set of these
so i can actually steer my truck in and out of the garage
then i need to get a longer bolt for to replace the stock one where i had the head heli coiled
install the new cams i got
adjust the valves
slot the trans cross member
THEN i can drop it in!
once its bolted in ive recruited Laecaon to do the wiring for the swap, install the new super secret "motor swap box", and do a wiring harness tuck.
once all of thats finally done it can go out for a new one piece drive line and exhaust
hopefully i can keep my canby list short for this truck this year.........
adjust the valves
Yes.... I have some things on order... Still a couple more things... but Im feeling good!
- Eagle_Adam
No I picked up another exhaust cam so I'm gunna run duel exhaust cams
- Skeletonbonez
- Cars: 81 210 2dr & 69 510 4dr
No problems with that.Eagle_Adam wrote:No I picked up another exhaust cam so I'm gunna run duel exhaust cams
Dual exhaust cam, Known as the 248/248 cam swap. You loose a ton of low range, a bit of mid range, and then your run out of revving before you take advantage of the cams. They would be better for Turbo, or if you were building a 8k rpm KA...
As far as Altima Cams go. Um, they arent different than stock S13 cams... Well ok the exhuast cam is timed a little retarded on the Altima, but same exact duration and lift as stock S13 exhaust. I dont get why people keep saying the Altima is an upgrade... Well I know, its an upgrade to the S14 which had 232/232 stock.
Why you studying up on KAs? Isn't a CA an upgrade over a KA anyway?
