--- Black ZXT ---
Re: --- Black ZXT ---
#21
Cheap 1/2" 10mm impact bit .. I couldn't imagine impacting with this thing ... trollol.
022 by 71240z, on Flickr
plop... like a bawse !
034 by 71240z, on Flickr
Head-gasket looks good. Will be re-using it...
:troll:
kidding... New HG :)
All the cylinders look pretty dang good ... can see cross-hatching in all of them and no scratches/scores/glazing !
028 by 71240z, on Flickr
#22
shot some pb blaster all the exhaust things !
Knocked off the down-pipe to get to the drain-plug.
012 by 71240z, on Flickr
Excellent play on turbine end (stock TB03 Ai-Research 280zx turbocharger).
011 by 71240z, on Flickr
Mineral deposits... tiny little trolls. Well played...
017 by 71240z, on Flickr
#23
Those cylinders look great.
#24
DRIVEN wrote:Those cylinders look great.
Indeed ! Thanks. Best part is you couldn't tell one cylinder from the other in pictures at a glance.
I was a bit shocked to say the least :thumbs:
#25
head on the left is for black zxt , and head on the right is from other zxt.
018 by 71240z, on Flickr
scraped off enough of the gasket surface(razor bladez) to use the Snap-On flat bars.
016 by 71240z, on Flickr
I removed ... just enough gasket material .... to use the flat-bar
:troll:
#26
015 by 71240z, on Flickr
knocked out (5) freeze plugs on the drivers side of the block.
014 by 71240z, on Flickr
013 by 71240z, on Flickr
:fry:
#27
You gots too many projects. I can't keep up.
#28
No kidding.
