Fast forward to Feb of last year..
Here it is sitting my driveway. I had just split up with my ex. So the purchase of this was on the down low. Ignore the oil on the ground, that's from her 97 voyager.
A drunken night in a field proved to be bad.
A trip to banners house... Good to go again!
Ownership finally on paper!
Randomness
Next was to remove the bumper and make a bozo pipe for this bad boy...
High resolution graphic design made in a really expensive photo editing program (three seconds in MS paint to be exact
Making it happen
First, pull the rusty truck out of the car port
Second, find the dead rat....
Braaaaaaaap. Along with this, the muffler was removed and a 14" resonator was installed. This car makes a perfect sound....
Next... Pop a head gasket, check... Replace head gasket, ok!
Next step. Bust a head bolt in the block... Then smash a nut on it with a 5lb sledge, run a bead around it... Done!
Head installed... Didn't take any more pictures after this. pretty self explained. Install head, torque bolts, set valves, put together.. Vrooom!!
Next, the goon needed a new motor. And well, pull the passenger seat, put the motor in there and haul it home... Its what us without a truck do, yo.
