71 510 goon with ka24de
Re: 71 510 goon with ka24de
dude sorry bout the wreck .. do u still have Miata... I need a Miata tranny for my b2200 and would be interested n a 1.8 dohc motor if its the 1.8
- squatches
- Cars: 71 ka 510, 71 1200, 3 620's, 95 s14, 89 ka24de rx7.
i do have a transmission its from a 1.6 the bell housings are the same from 1.6 to 1.8 and i think they are the same internally, but i dont think you would want to travel all the way to georgia for a transmission lol. i But if i rememeber right the miata trans wont workin in the b2200 because the bell housing, tail end, and shifter position is different.jrock4224 wrote:dude sorry bout the wreck .. do u still have Miata... I need a Miata tranny for my b2200 and would be interested n a 1.8 dohc motor if its the 1.8
u only use the gear box and u can bolt the tail section and the bell housing from a b series tranny and its done ...
- squatches
ah ok i was thinking the housings were diff but didnt know you could bolt the internals in, but i do know the internals on the 1.6 and 1.8 are the same for the miata trans.jrock4224 wrote:u only use the gear box and u can bolt the tail section and the bell housing from a b series tranny and its done ...
box the ceter up and send it out ..... u can keep the tail and bell ....
- squatches
if serious inbox me and i can make it happenjrock4224 wrote:box the ceter up and send it out ..... u can keep the tail and bell ....
- squatches
today i actually got to drive the car for the first time with the ka in it, still need to get exhaust made and fix the idle issue but atleast it moves under its own power now.
- squatches
got an exhaust manifold from a freind and put it on today after about 30 min of grinding.
now ive got to clean up the engine bay and paint it, then get all the bits and pieces that im missing for the engine.
Nice work man props to you
- squatches
thanks! hopefully it will be driveable in a week or two.510freak wrote:![]()
squatches wrote:thanks! hopefully it will be driveable in a week or two.510freak wrote:![]()
Nice !!
- Eagle_Adam
any idea what header that is?
- squatches
it has a jvt tag on it i had to cut and grind the O2 bung off of if to clear the steering box in the 510. I just got a bolt the had the same threads as the O2 location and threaded it in until it bottomed out and then cut what i had to cut out and grind to make it fit. but it clears the steering box now, the side bung for the o2 has to be cut/grinded pretty much flush with the piping to clear the stock 510 steering box. ill get some pics of it later on when i have some one with a camera around, mines not ground all the way and i still have a few millimeters of clearance but it would be better if i had done away with the port to begin with.Eagle_Adam wrote:any idea what header that is?
- squatches
went to go drive the wagon and the maf takes a shit on me..
im starting to think this car doesn't want me to drive it.
squatches wrote:went to go drive the wagon and the maf takes a shit on me..im starting to think this car doesn't want me to drive it.
It will happen soon
- squatches
surprisingly there are no mafs on cl any where near me lol, but the 510 is sitting outside for awhile a friend needed a place/help to swap his motor so ive been doing this..
- squatches
finally found a maf for it then get everything back on, crank it up and it starts throwing knock sensor code..
so i replace the knock sensor with one from another block i have still same thing... turns out the sub harness from the sensor to the main wiring harness had fried somehow. cleaned up the engine bay and sprayed what i could get to with the engine still in, made it look much better even tho there's still some spots that aren't painted yet.
hopefully ill be pulling it soon to sand and paint the whole bay.
- squatches
finally got to drive it down the road toady to go get exhaust done on it. so many boners were had on the way there!!!
- squatches
cleaned all the over spray from where my dad sprayed primer on his ranchero.
fender is cleaned cowl isnt you can see a big difference lol.
now for tag and insurance.
