It's $3.something a gallon right now, but it's good to know because I only knew of the one Ma and Pa place in Hazell Dell on NW 119th before today, this one is close to me.
OK, so on my way down to check this out above in MY MGTD I seen something I had not seen before, a light on my dash started flickering, now I knew what the light was for, but I thought that it had burnt out or something, because when I wired it up it stayed on all the time, you see it is a low fuel light, I don't have a fuel gauge, the MGTD never came with a gauge, it came with a low fuel light, so initially when I wired it, I thought the arm in the tank was stuck in the down position(rusted/float had sunk or had holes in it) even though I had filled the tank, so I bought a new unit to put in the tank, well one day when I turned the ignition on, the light didn't come on anymore, that is the reason I thought it had burnt out or my wiring had failed, well it is working now, when I went around corners or hit the brakes it flickers, so maybe after another few miles it will just stay on, and I will not have to empty the tank to put the new unit in because the old one works, it's kinda nice when something works itself out, that don't happen a lot around here.
