Adam's annoying ass green 620
- Eagle_Adam
well i think im done dying now!!!!!
today is my first day back at work, so i hope to go home and finish up a few things on my dads truck and put some bump steer spacers in the gloon then its back to my KA swap!!!!!
Glad you're up and running again. Just like the truck will be soon.
- Eagle_Adam
Got the center link flip done with Jesusno2 today!!!
Welded up the holes
Center punched and re-drilled
And then re tapered from the opposite direction
Now I'm off to Eugene to meet up with the gang down there
Welded up the holes
- Eagle_Adam
well, im almost ready to drop the KA in!
ive got a few more small things to take care of when i get home tonight then i caqn install my flipped center link!
also heres a great write up on what you can delete from the KA intake mani
http://www.liquidmathematics.com/temp/EGR-Removal.pdf
- Eagle_Adam
- Eagle_Adam
Picked up the Tie rods, a galon of purple clean, and a coupla can of brake cleaner!
Later this week ill have all the steering components cleaned up and installed. If i find extra time im gunna clean the emgine bay too
- Eagle_Adam
What are they?
- Eagle_Adam
tire valve caps
- jayden71
- Title: Bewb Captain
- Cars: '71 Viagra blue 521
- Eagle_Adam
That moment you snap a bolt and come to the sad conclusion that you need to go all the way back to the block to fix it right .....
Ya that moment can fuck up ur Saturday.....
Grumble grumble grumble....
I want to thumb-down the situation without negging the poster. Sadly, not an option.
There's got to be another way...
I'd pay someone at a shop to do it rather than tear it all back down.
- Eagle_Adam
There isn't another way to do it CORRECTLY......
It's. $150 - $200 mistake :/
Can't really tell where it is. Right front of the head going into the timing cover?
- Eagle_Adam
Yup, from one timing cover to the other right thru the head gasket :/
I know it'll probably bug the shit out of you just knowing it's there, but honestly I doubt it would be an issue if you just left it that way. that little bolt isn't doing much in the way of clamping force. Probably more for alignment than anything else. Can the upper TC be removed by itself? That should give you enough access to drill it and use an extractor...if you must remove it. Shouldn't cost you more than time and some RTV.
- Eagle_Adam
I just can't leave it that way....
And it will cost me a head gasket and new headbolts to fix it :/
