the mine now coupe.
Has thanked: 2 times
Been thanked: 2 times
Re: the mine now coupe.
#341
Post by RedBanner »
My old impact I had to torque them. Afterwards still. New impact breaks em right the fuck off.
But learned my lesson, its fixed, got new bolts altogether.
Also got new studs, and bolted my manis on for the last time, and jam nutted everything. I like jam nuts.
levigideon
Cars: 72 510 Wagon
#342
Post by levigideon »
RedBanner wrote: Image
:gscot:
OH SHIT.
So much jelly.
This will be a screamer.
#343
Post by RedBanner »
Basicly stock.
:D
levigideon
Cars: 72 510 Wagon
#344
Totally stock. I see nothing special. :rofl:
devilsbullet
#345
Post by devilsbullet »
looks awesome man. cant wait to hear(and see) it screamin
#346
I like screamers.
Wait wut?
#347
i keep seeing T at the end of a14. i thought that meant turrrrrrrrrrdo? I spelled it like that on purpose.
#348
Post by RedBanner »
Nope, it means twin hatachi side drafts, dont know what exactly it stands for (the t) probably something Japanese.
#349
Post by RedBanner »
Cut my l series linkage.down to fit, and added a cable throttle provision, was realy fiddly, and I thought it out extensively before I welded it up. Tried to leave room for.adjustment in every directions.. turned out pretty good. Didnt take pics. Got my oilpan cleaned.and painted, the inside had gotten.so gummed up that after an hour of scrubbing I painted the inside also, just to avoid the work next time.
#350
When brian and I pulled the oil pan off my L series, we had seen a lot of nasty shit in there too. I dumped some gas in it, and let it burn for a while... then this dry powdering shit just fell out instead of me having to clean it lol
#351
Post by RedBanner »
So, any one well versed in the later l16 su crabs?
I would like to know how these tubes function, and how they sould be adjusted, and do the connect like this?
The top one goes to the rocker cover?
Or? Whatever, heres my linkage, cut it inhalf and then pounded a rod into the center, so it was a friction fit before I welded it. The steel rod inside would have probably held it without welds tho, was alittle bigger diameter than the hole in the linkage
. Image
Motor guts be clean still, only has around 7k since it was rebuilt, the head I slapped on was alittle fresher than that even.
#352
Post by RedBanner »
Compression is 9.4:1... a series guys might know whats up with that. Lol
#353
Post by RedBanner »
So the tubes. They get blocked off. So no questions there anymore.
uberkevin
#354
Post by uberkevin »
The whole plat really can be taken off and blocked.
#355
Post by RedBanner »
Yeah, pulled them off, and ill make little triangle plates. Off to work for now tho.
#356
Post by RedBanner »
Worked 14 hours tonight, managed to get my pan on when I got hoke, but thats it, im crashin.
#357
Post by RedBanner »
25 hours on the timecard by tuesday morning,,,, no datsun time today, off to sleep
#358
Stackin chedda, yo!
#359
Post by RedBanner »
Hole punch was no where to be found, so I ground the end of a peice if tube down and smashed it thru my gaskets.
Bout to bolt the trans on, bolted the carbs on already, might be a mistake because of brake master clearences, but im thinking I my move the engine ever so slightly to the passenger side, so I can clear my airbox
Eagle_Adam
#360
Post by Eagle_Adam »
Hit thumbs down by accident.....
