The Blue gO_0n Build?
Re: The Blue gO_0n Build?
#201
Nylocks suck. All about crush nuts.
No need to remove the wheel.
H5WAGON
Cars: 1970 510 Wagon L20B.32/36 Weber, 4spd....5spd on Deck!
1970 510 Wagon L16...32/36 Weber, Automatic
#202
Post by H5WAGON »
A boltless solution...
From a mustang site.
Might not clamp down far enough though.
Ebay...
http://www.ebay.com/bhp/leaf-spring-clips
H5WAGON
#203
Post by H5WAGON »
This type installed....with flaps bent over. :gscot:
#204
I prefer the bolt method, as you stated, it probably has more tension. Tension stops the leafs from sliding between each other. Thus stopping axle wrap.
Doctoraudio
Cars: 1969 Datsun 510 wagoon
#205
Post by Doctoraudio »
I forgot who.
But a guy was telling me about drilling thru the spring to do that.
And only using one bolt on each side of the spring.
I am interested in other thoughts.
How feasible is that?
#206
I don't think you'd want to do both sides of the spring, if you mean to the front and the rear of the axle. Kind of takes the spring out of the spring. The way it was explained to me was to was that you wrap/clamp the front to essentially make them solid(ish), like a trailing arm. Old hot rodder trick.
#207
Drilling leaf spring sucks. Also like driven said, you only want to do the front or rear, and each has its strengths. For our applications, keep the clamp in front of the axle.
Draynor
Cars: 71 510 wagon
#208
Post by Draynor »
All new Moog steering components were under the tree this year :thumbs:
Doctoraudio
#209
Is that motor done yet?
Draynor
Cars: 71 510 wagon
#210
Post by Draynor »
Pretty much ;)
#211
Ha nice dude. Jelly
#212
OOOO nice!
You may want to order a few bushings while you are down there...
LCA/Swaybar/TC rod bushings. Luckily those are all cheap.
Draynor
Cars: 71 510 wagon
#213
Post by Draynor »
Yeah, gonna order the sway bar ones for this 1" bar I have. But I might be getting some adjustable LCA's and T/C rods...So might not order those bushings just yet.
Draynor
Cars: 71 510 wagon
#214
Post by Draynor »
Finally picked up the BMW seats from my friend :D The color is close to the 510 stock red, but not perfect. I am thinking I might try and find the red vinyl paint for the BMW seats and paint the panels and such to match, since they are very faded anyway.
Also found 1 center cap at "H5WAGONS's" house, fits perfect! Anyone know what it's from? Looking for 3 more or a set!
#215
Looks like the caps I had on my '80 210.
#216
I was thinking 210. Gray would know.
Doctoraudio
#217
80's 210
Eagle_Adam
#218
Post by Eagle_Adam »
Sneak peek
It's almost done
Eagle_Adam
#219
Ready and waiting for Laecaon to get off work and tune the carbs :)
Got some cleaning done too
Before
After
Draynor
Cars: 71 510 wagon
#220
Post by Draynor »
Big thanks to "Laecaon, Eagle_Adam, Jassifrass, H5WAGON, and anyone else who helped along the way!"
I was amazed of the power on the first drive! Even though there is a fuel delivery issue going on, it hauled ass on the way home! :D :D :D :D :D :D :D
