Rory's 72 510
Re: Rory's 72 510
The 620 has a good carb so I will put that on and check everything, definitely a vacuum leak somewhere but now I have a baseline
MicroMachinery
Re: Rory's 72 510
That definitely sounds like carb issues. Not surprising if it sat for as long as you say it did with fuel in the carb.. ports are probably clogged with goobers.
Re: Rory's 72 510
Took the taillight off and cleaned it up. Was trying to figure out something that would remove the cloudy oxidation from the lense, baking soda paste worked the best.
Re: Rory's 72 510
mmmm.
I've always wanted a running 2/4 door. Have alwayas ended up with wagons
Re: Rory's 72 510
That came out really good Rory.
- Ni10
- Has thanked: 119 times
- Been thanked: 24 times
Re: Rory's 72 510
wonder if toffpaste could be used -------------------------------------------------------- for polishing the lens.
Re: Rory's 72 510
I use baking soda to clean jewelry and it works really well when rinsed with boiling hot water after. Toothpaste not as good but works in a jam. Working on the grill and surrounds now
Re: Rory's 72 510
I have wifey for that nowNi10 wrote:wonder if toffpaste could be used -------------------------------------------------------- for polishing the lens.
