I know its not.. but I saw it the other day in traffic. You can see in the pic... it smoked bad.. Burning oil for sure.
draker » Fri Apr 10, 2015 1:51 pm wrote:Is that you wayno?
I have lots of SUs around here, but they are jetted for a dual setup, so each one is made for about a 1000cc, this engine is a 1500cc, so I don't believe it will work right unless it is re-jetted.DRIVEN » Sun Apr 19, 2015 7:02 am wrote:I never did like the way those Strombergs ran. My brother's Volvo had dual Strombergs on it when he got it and we never could get it to run right -- or smooth. Slapped some swap meet SUs on it and it was night and day better.
DRIVEN » Sun Apr 19, 2015 9:39 am wrote:I wonder if a single SU from a 240Z would be jetted close enough to run okay?
izzo » Mon Apr 27, 2015 10:27 pm wrote:Would it be easier to just get a painless or other type kit? Idk what all you plan on putting into the car, but they seem decently priced for a smaller harness. Seems like it would be the way to go if you're going to rewire it. A lot less likely to have something not work, or work then not like the alternator.
DRIVEN » Sat May 02, 2015 7:44 pm wrote:The Black and white wire is the power feed from the ignition switch. Goes in to the distributor, then through the noise suppressor (condenser) and then to the + side of the coil.
