Bogusly Blighted Buseymobile .. aka Lowla is For Sale
Indy510
Has thanked: 27 times
Been thanked: 132 times
Re: Bogusly Blighted Buseymobile .. aka Lowla is For Sale
#161
Post by Indy510 »
So we are finally back to the beginning of this thread: ... after the North-Bay fun run was over:
Indy510
#162
Post by Indy510 »
Indy510
#163
Post by Indy510 »
Indy510
#164
Post by Indy510 »
The fake rust looked okay for a few weeks, but then the clear coat faded ... and the fake rust started to look like shit ... literally:
It needed more contrast, from light to dark: .... so I broke out a blow torch, to add some dark spots :lol:
Indy510
#165
Post by Indy510 »
Then I found a bigger problem: ..... the driver's side T/C rod cups were rusted, dented, or missing:
So i started picking at the flattened out cup:
Indy510
#166
Post by Indy510 »
I blame the shitty poly cone shaped bushings I had on rusty ruby (bottom of pic) ..... the top of the pic is stock rubber/sleeve bushings to replace it with:
Indy510
#167
Post by Indy510 »
I found some steel engine core plugs, that fit the stock bushings good:
Indy510
#168
Post by Indy510 »
I didn't have a drill bit big enough ... and I had to dremel off all the zinc coating, before any welding:
Indy510
#169
Post by Indy510 »
Cleaned off all the paint/rust off both sides of the T/C rod mount:
Indy510
#170
Post by Indy510 »
Installed the new cups, and bushings, tightened the T/C rod most of the way ... and matched it's position with the passenger side T/C rod: ... before tack welding both cups:
Indy510
#171
Post by Indy510 »
Then hammered the cups till they matched the shape of the body: ... and welded with heat this time (I didn't want to melt the bushings with the first few tacks)
Then more heat .... hope I don't ever have to take these off ... :lol:
Indy510
#172
Post by Indy510 »
A few hundred dremel cut off discs later...
Indy510
#173
Post by Indy510 »
Indy510
#174
Post by Indy510 »
Let's hope this works:
#175
Pretty good idea there.
#176
Down here we call that "redneck ingenuity"
Indy510
#177
Post by Indy510 »
One last fix, before the test drive: ... the steering stop bolt was missing, on the drivers side:
Passenger side still had one:
Indy510
#178
Post by Indy510 »
So I measured the passenger side's, and made a new one:
Indy510
#179
Post by Indy510 »
reserved
Indy510
#180
Post by Indy510 »
reserved
