Jacob's goon build
Re: Jacobs goon build
#141
inches. lol.
#142
So due to random events, and the way things are unfolding, I finally got a date to take my car in. December 28th. This is a good time for me as I should be mostly done with all my running around and what not. Also, I should have earned my money doing house work.
I did manage to pick up a new T/C pocket and Rod from Dave Bothwell. He works near where I live so that made it easy.
Also, I am suddenly doing a ton of research for this car.
Eagle_Adam
#143
Post by Eagle_Adam »
when are you not doing a ton of research.......
#144
Haha thats true. I usually spend the last hour or 2 a night just brainstorming.
#145
Got back from camping today. Winding down the day. I repaired a hair straightener for my sister (wire needed to be resoldered).
Then I decided that I should do something regarding the car.
So one problem with the car, my Headlight exploded. Well I sent the good people over at TheRetroFitSource.com (BEST guys ever regarding all things HID/projectors, amazing customer service and tech support) an email about my car and about the possibility of buying just a single lense and HID bulb. They had no issue with that and promptly sent me an invoice. And it was shipped ASAP. Yes, I was able to buy 1 lense for my projector, and 1 new 5000k 50W HID bulb.
Anyways pictures.
Here is my Passenger side headlight still intact for reference.
Bare Projector Housing, notice the missing lense.
Carnage! That poor lense got chipped every which way.
And Im not sure if this bulb is actually bad or not, but better to just replace anyways.
Yes the new bulb, 5000k for that Super White look with no Blue at all like the common 6000k.
New lense, notice the way the 2 catch the light.
Disassembly.
Fore-ground limiter as well as the high beam limiter (not sure why a high beam limiter is needed...)
The plate that makes the "Step" in the light output.
And Lense is back on.
I have also started onto the BMW housing.
Eagle_Adam
#146
yay for progress!!!!!
#147
I don't know anything about the place you get your HID's from (although I will check them out in the future) but I've gotten my HIDs from DDMTuning. The bulbs are fairly cheap although I don't know what size you use. Maybe could be a back-up. Do you know what caused the lense to explode?
#148
DDM tuning. They are hella cheap. don't off what I want. I use D2S, its an OEM HID size. And most don't carry the 5000k color.
lense exploded in the crash, all I know.
#149
Sucks they don't have what you use. They do have 5000k though, for my pathy & the wifes car anyway.
Ah yeah the wreck, sorry I had forgotten about that. Good on getting it done. :thumbs:
#150
Well I had swapped my motor into my friends 521 to go camping. Needed the extra power for the hill climbs. Let us do 65 the whole way. But my clutch slipped in 4th alot, but not the other gears... Anyways we swapped back last Sunday. Let my motor just sitting in my car. Tonight I buttoned it all up, got the car running again. I forgot the exhaust wasn't hooked up, open headers sound amazing on this motor! Found a fuel leak on the rear carb hose. Tomorrow evening taking the car to my work. Then Saturday morning I'll drive it across the street to the body shop, and hopefully it will be all straight. I'm excite!
Eagle_Adam
#151
WOOT mother fucking WOOT!!!!!!
#152
sweet man! Glad to see this thing getting fixed and back on the road.
#153
Got my birthday present! A NRG thin quick release! Mounts to my Momo hub.
#154
And after much hassle tonight, I got my car to work.
Eagle_Adam
#155
Sry about that man.....
Good to see it made it tho
#156
So I took the car across the street. Its being worked on now. It will be ready at 4pm, and they are charging me $400. I cant wait!
H5WAGON
Cars: 1970 510 Wagon L20B.32/36 Weber, 4spd....5spd on Deck!
1970 510 Wagon L16...32/36 Weber, Automatic
#157
Post by H5WAGON »
Less than 3hrs now!
#158
So after today:
weld on T/C pocket, install rod.
start body work on valence (half heartily, its dented so much), hood, and drivers fender.
Paint what I need to match.
acquire new headlight bucket assembly.
tires for the rikens.
and sss left grill piece.
#159
And some pictures after I received the car:
#160
And finally, some tools:
Ridgid 18v 1/2" drive impact. Uses same battery as my drill and sawsall.
And to go with the Impact:
