Nightfap
Re: Nightfap
No offense taken, thanks Keith!
Re: Nightfap
oh shit
Re: Nightfap
I did a little trading and this is going back in my car port......
Re: Nightfap
Right.
Looks like I'll need that weber after all
Bahaha. I need to go and get the head for this thing so i can get it drive-able.
- Eagle_Adam
Re: Nightfap
ill have a complete running L motor after i DEQ...... with 5 speed..... just sayn
Re: Nightfap
Dear lord baby jesus.............
I don't have any monies
i'll have a KA 5 speed, a hardbody gas tank with intake fuel pump you could install the whole tank on your truck, though. (so no need for an inline noisy pump... this one is in tank and rated for KA...... A flywheel and good clutch.....
- Eagle_Adam
Re: Nightfap
ive got all that, and a new tank for my truck.....
just figured id put it out there
Re: Nightfap
Bummer.
PM me or shoot me a text on what you're looking to get for this stuff.... And maybe after some parts sell....
Re: Nightfap
I looked at the head gasket, i couldn't find where it popped. but i can assume it wasn't torqued down right, look at that head bolt! But also, the head gasket looked super old, like original... It's not new, and used at the least so it wasn't anytime recent.
Re: Nightfap
^^ also, pics are backwards lol
Re: Nightfap
mmmm slug
Re: Nightfap
Maybe a crack , check between the jackets.
Chances are it isnt but for safe measure
Re: Nightfap
once I clean the block surface off i will check for cracks, the head is garbage... i'm not even gonna fuck with the head. I have a replacement in much better shape, looks new almost.
The front three pistons are clean as fuck, back one is dirty. it must have been blown blown? but the head gasket doesn't look fucked up... IDK. Check for cracks on the block, slap the new head on it after i set my straight edge on it, and GO!
Keith,
74 620. but has an L20 in it with W58 head.
Keith,
Re: Nightfap
^^^ Will do. normally i just replace a part and go, but it is wise to know what exactly went wrong.
Speaking of which. Whoever put this motor together should have their hands cut off. I'm no pro, not even close. I am still learning. But, I do know you should tighten bolts. And when one hose clamp doesn't fit, you don't put two together to make one... I mean shit really? they are two dollars...
Re: Nightfap
Looks like the front pistons had a good steam-cleaning. HG?
Like Jacob said, check head.
If you have a garbage shock/strut laying around-cut it apart so you have just the shaft.
Makes for an awesome, cheap straight-edge.
Re: Nightfap
Oh yeah, head gasket was never in questionl I just can't figure out where it blew out man. No obvious signs. usually the HG is fucked up in a spot or missing all together and been burned out of the motor. I checked the oil and its milkshake. i know the HG popped... Just dunno why.
That fuckin cam bolt was tight, the only tight bolt I came across. Turned my breaker bar into a fuckin horse shoe. Had to break out the 8" cheater bar (piece of pipe) to get the fucker to come lose. Ended up putting it in fourth gear, then putting a wedge behind the rear tire, and went to town... I was pulling so hard i lifted myself up off the ground, shoved into the fender then had my feet against the wall. I've never had a breaker bar bend like that. Was worried it'd bust and I'd have ate it in my face
