Jacob's goon build
Re: Jacobs goon build
#121
Mmk. The sliders on these new ones are in great shape and function well. The paint is still glossy. Considering my car already has mr2 sliders, I don't need 2 pairs.
and yes, my friend already told me to do quad buckets...
#122
Quad buckets in a 4 door has always been a want of mine.
Doo eet!
#123
sweet. well let me know what you wanna do with em.
#124
I want to give them to you...
#125
Oh and wagons do have rear shoulder mounts for seat belts...
#126
Laecaon wrote:I want to give them to you...
I gotta make a few trips to your area over the next week with home skillet still in the hospital. I'll let you know when I go that way and maybe we can meet up. I still got your carb in a box :rofl: I should bring that back some day.
#127
Well, here is a picture or 3...
So I did some random stuff today, mostly making it so I could walk in my garage. So that is one of my Riken mesh wheels that I will be using until I can get my weds back on the car.
And then I cut the good part off my fender, and threw the other half in the garbage.
And then a pic of my bent eyebrow peice.
#128
wow. crazy how the back half was pretty ok with the front half being destroyed.
#129
You can straighten that eyebrow. Just sayin, it'll buff out
#130
So today I did some stuff with the car.
I wanted to run the motor, let it get warmed up, idle for awhile, blah blah blah. It hasnt ran for more than 45 seconds since the crash.
So I needed to mount the radiator, but I had lost the hardware... Off to Home Depot... Anyways got the radiator bolted in. Connected all the hoses, and filled it with water. Turned the car on, and just kept filling until the thermostat opened. Then I shut the car off and drained the water. It was mostly clean, a little red, but still clear.
I was doing some research on coolants, since everyone manufacturer makes their own now, something had of changed since the days of the green stuff... Well basically, keep using the green stuff, or change to G-05. I get bored, so I switched to G-05. Its clear in color, and thats odd...
Anyways, Down pipe is still only connected to manifold with 1 nut, but the manifold has all 3 studs. Minor exhaust leak there. Something on the exhaust is rattling. And I really need to do a valve adjust.
Other than that, man this car just fired right up, and instantly revs. I miss it so much.
Then I tried a compact battery my friend gave me. Since the car was warm it was easy to start. Well the battery just barely started the car, but thats to be expected when its under 12v... I let it run for like a half hour charging.
Car still warming up
Idling at 750-800
Finally the Thermostat opens!
Coolant I am now using... It says Older Jap cars right on it! Must be true...
Tiny batter is tiny
I still have the old battery cable ends, but I figured out how to get it to work.
#131
Post by 510freak »
:thumbs:
Glad you got it going Jacob,Those gauge faces sure stand out(in a good way) Make for better night driving?
#132
510freak wrote::thumbs:
Painting the gauges white made them 100x easier to see. Then I did a custom LED setup. Those LEDs are actually dimmed a decent amount. It can get a bit glaring.
But none of that is staying...
#133
This update makes me smile...vroom .. vroooooom .. :D
#134
Post by 510freak »
:thumbs:
Sure looks like they are easier to see,The 194 led conversion?
Oh,None is staying,cant wait to see what you have in store :thumbs:
#135
Body shop appointment yet?
#136
Body shop appointment?
Erm, This Saturday possible, or Next... I has money, need them to have time, and my co workers truck to be working again...
And no, not the 194 LEDs. Custom... I cant do LEDs like other people, it hurts me...
As seen in this pic, I have 4 bare LEDs making a ring around the gauges. They are actually hot glued in, and pointed directly at the gauge faces. This picture is a little contrasty, or I have the LEDs at full brightness making it real hot spotty.
#137
Post by 510freak »
:thumbs:
What may be kind of neat is a circle pattern led around the speedo/tach/clock(factory)If that makes sense)
#138
+1 on the ingenuity of hooking up your battery.
Did that Odyssey start better after some charging?
What size is it?
#139
I dont know, I just turned it off and left.
That is the PC680. I have plans for it to go under my rear seat.
dimensions are
7.27 3.11 7.55
#140
Is that metric?
:lol:
