Adam's annoying ass green 620
Eagle_Adam
#101
Post by Eagle_Adam »
DRIVEN wrote:Didn't someone post a pic of a tool for that? :roll:
Yup... But it only helps when it's in
Eagle_Adam
#102
Got the 720 cleaned up and pushed out into a spot.
And got the 610 parts put away safely in the rafters
So Then the 610 came in for engine removal, it's a good running l20 but I can build another and I'm short on space...
So it's headed to big Schlink!
The truck will hopefully be back in the garage by Friday... Gunna be a busy week
#103
I have a hammer handle I use. Has worked on 4 chains thus far. Im not a fan of wedging the chain. Just stopping the tensioner from coming out at all.
Eagle_Adam
#104
Laecaon wrote:I have a hammer handle I use. Has worked on 4 chains thus far. Im not a fan of wedging the chain. Just stopping the tensioner from coming out at all.
The "wedge" I have does exactly that, goes down far enough to stop the tensioner from popping out
Eagle_Adam
#105
I've spent the last few weeks with the 720 in the garage and it made me lazy....
But it's done(outta my garage and onto its new home)
Had a couple hitch hikers the other day
And this guy decided to chill the whole ride home
Eagle_Adam
#106
The last couple days have consisted of cleaning and organizing.....
Yawn
But with a few new shelves and some organizers
BAM!
Picked up a bolt/nut organizer with removeable containers
And jessi got me two long over due tools......
:D
Eagle_Adam
#107
Since I was on a roll I figured I should probably address my lack I breaks....
One of my two favorite ass to see up in the air
Rear diff was leaking
So it got new fluids and a wipe down
Onto the brakes!
Which for the first time ever from a PO looked good!
Newer shoes and cylinders :)
So I adjusted and bled them.....
Only to find out I'm missing an ebrake cable on the pass side....
But whatever, one side works ill address it when I do the rear disc swap :/
#108
ever get your lack of brakes figured out?
Eagle_Adam
#109
yup, after readjusting the rears and bleeding the system again im back up to par and as of this morning(unlike previous attempts) i still had the same brake pressure when i started her up this morning so time will tell. If it hold then i can move onto the rear disc swap.
#110
Eagle_Adam wrote:yup, after readjusting the rears and bleeding the system again im back up to par and as of this morning(unlike previous attempts) i still had the same brake pressure when i started her up this morning so time will tell. If it hold then i can move onto the rear disc swap.
It could have been the rears all along maybe? When the rears are adjusted in(think of the shoes going inwards, away from the drum) More fluid is required to run to the back of the brakes, and will cause the pedal to be closer to the floor before it works. there for if you pump the brakes, it will build up the fluid going to the back and make the brakes work like they should. soon after you don't use the brakes they will return to shit state. with them adjusted properly, the brake pedal should be right there at the top. Discs will eliminate that BS.
Canby 09 I lost my brakes unless I pumped. Someone told me exactly what I just wrote, i giggled and said that don't make sense. Naive I was! I can tell when my brakes need adjusted by the pedal getting closer to the floor before they work. Speaking of, they be due for adjustment again :rofl: Working in seaside sucks, 589234890890 stop signs (damn near every block) so I use my brakes more often then the gas pedal it seems. Have to adjust them every few weeks.
#111
I can tell my brakes needing adjustment by how far I have to pull my parking brake.
Eagle_Adam
#112
Just picked up a full DE swap!!
And a 5speed....
Huge thanx to Redbanner and Draynor for the help pulling the motor!
Eagle_Adam
#113
really? i get a KA, 5speed, ECU, and harness and not one comment......
you guys suck
#114
:rofl: It's cool man, its cool! I watch the thread even tho i don't say to much. waiting on install pictures :D
Eagle_Adam
#115
this is just for my reference:
gasket kit
timing kit
Flip center-link
fuel pump( inline pump near the tank, with a filter between it and the tank.)
power steering delete
exhaust mani if the header doesnt fit
redeye mounts - http://community.rat...mount-brackets/
truck KA slave cylinder and hose
centerlink, ball joints, and tierods, end links, and sway bar bushings
reverse taper for flipped centerlink
new exhaust..... again
pathfinder accelerator cable
3 or 4 90 degree bends for the heater hoses
figure out radiator hoses
powder coating
figure out ECU mounting
nail down wire and relay routing for the wire tuck
fuel line clamps from a maxima (JY grab) and new high pressure fuel line
theres probably more :/
#116
electric fans? Radiator? Honestly I would see what a stock 3 row would do.
#117
The way you work you should have all that done by 2:38 a.m. On Thursday
Eagle_Adam
#118
Laecaon wrote:electric fans? Radiator? Honestly I would see what a stock 3 row would do.
true.... forgot about the fans..... and by default the control switch
Redeye used his stock rad and it works to this day so im gunna go that route and pray
Eagle_Adam
#119
Taterhead wrote:The way you work you should have all that done by 2:38 a.m. On Thursday
LOLZ!!! if it was all bolts then ya.....
but the wiring will take a couple weeks to be done right
Eagle_Adam
#120
izzo wrote::rofl: It's cool man, its cool! I watch the thread even tho i don't say to much. waiting on install pictures :D
i know, just teasing :D
someones gotta do it
