Country slice
- Has thanked: 671 times
- Been thanked: 245 times
Re: Country slice
Allegedly , 55’ farther , as far as it would go for the alleged total depth of 120’ drilled in 1987. Next door neighbor says the level has dropped 31’ over 30-years since he’s been there. Hope that trend continues.
Re: Country slice
Try not to live 56 more years.
Re: Country slice
Unforecasted Wind storm blowing stuff enough + 40’ maple tre e = buzz buzzzzzzzzzzzzzzZZZZZZZZZZZZZZZZZZZZZ....saw time.
The victim requiring amputation It was much taller than the pic shows , and the limb(s) landed 4” away from piercing through a custom sized window.
Two words = super lucky
Re: Country slice
Lucky indeed. I didn't even know maple trees grew down there.
Re: Country slice
Re: Country slice
One ant , one red ant , got *fried* between the contact switch points on my water well pum p when the pressure switch started to cycle on @ 40psi (shuts off @ 60psi). This...Caused the switch to insulate and not cycle the pump. Went out @ 12am after water pressure dropped to nothing , switched off everything cleaned it up , filed the contacts , and sprayed for insects. Mind you , this contact switch is like 2-months old.
220v copper wire cleaned up after...the bottom pic taken.
Re: Country slice
Ants are inconsiderate pricks.
Re: Country slice
Very much so. Shits are attempting to get free room and board all around my house.
Re: Country slice
Not much to say other than enjoying some Home grown below. Next time we will hopefully by able to pay more attention and care. This year has been a busy one.
Re: Country slice
My Grapes are not even close yet, but I am eating Cucumbers(4 types), Cherry tomatoes, Blueberries, Raspberries, Romaine Lettuce, and I picked my first sandwich size Tomato today but have 1 and a half store bought Tomatoes left before I start using them out of my garden.
I think it was too cold this spring for Strawberries this year where I live, I got a few good ones, but they were smaller than usual.
Re: Country slice
Taking one from waynos book. Get home and eat grapes right off the vine. Have to be faster than the spiders or ants though.
With more attention , they’ll be larger next year. Waiting for oranges to come around as well.
Re: Country slice
I'm hoping to have that problem next year.
Re: Country slice
Re: Country slice
Super jealous.
Re: Country slice
We lost a few to freezing weather at night , so I made the painful decision to pick all of them in fear of losing more than taking a chance
Re: Country slice
I don’t eat oranges but my son would clean that tree.
Down here in the peach orchards they spray the trees with sprinklers all night to keep them from freezing. It seems counterproductive for my simple brain but supposedly it works. Maybe something you could do/look into.
Re: Country slice
Thats a good tip. Considering I'm a city boy living in the country , i’m a little more receptive to suggestions/experience.
Re: Country slice
Lots of water down here (for us , for PNW guys its a normal day) . Had to sand bag low areas in the back acerage.I guess some birds/egrets swimming in the pond areas.
Amazing how much sand you can get in weight ve coverage. I suppose having it delivered by truck is the only way to go. Alas , i got the sand free bagged by prisoners... courtesy of the state.
Re: Country slice
Cooling fan module failed on the wifes car @ 128,280 miles. Tried an amazon special $17 one to test (knowing it would be 50/50 DOA). Solved the issue. Will be ordering a factory one once i sell my kidney.. tested evrrything else. Debating....to quickly adding a 2nd ground as a redundancy to the system (wife drives this car 98% of the time).
Tore the old one open out of curiosity.
All of this is fine
All of this is fine
Re: Country slice
Remember back when it was a thermo switch and a simple relay? I long for simpler times.
