Hidden from J.S.
Indy510
Has thanked: 27 times
Been thanked: 132 times
#61
Post by Indy510 »
Drove around on 3" blocks for a while, with horrible driveshaft slap ... so I decided to lower it moar:
Indy510
#62
Post by Indy510 »
Flipped leaf maybe lowered it 10mm:
Indy510
#63
Post by Indy510 »
Indy510
#64
Post by Indy510 »
Before 3" blocks and a flipped leaf"
After:
#65
Nice and level. Looks great!
K_trip
Cars: DATSUN
67 Bluebird R16/5spd
71 510 Goon L16/4spd
74 Li'l Hustler L16/4spd
#66
Post by K_trip »
Eagle_Adam wrote:Drool...
+1
Ni10
Has thanked: 119 times
Been thanked: 24 times
#67
Post by Ni10 »
really love them wheels on the 710. The 710 looks sweet that low.
give me the 710 please.
#68
Wow man that does look good. Good idea on the bench vise. I should of done that with the 720 lol
Indy510
#69
Post by Indy510 »
Sorry we're still back in time, before the new driveshaft tunnel .... it needed a lot more hacking to drive at the height above:
But the driveshaft was still hitting .... so I welded in a brace and stopped driving the car for 8 months:
Indy510
#70
Post by Indy510 »
It finally wasn't rubbing with 3" blocks .... so I tried 5" blocks: ... :lol:
Indy510
#71
Post by Indy510 »
then it hit this thing:
Then it hit this part:
Indy510
#72
Post by Indy510 »
Woops.... too much sawzall ...... might as well C-notch it now:
#73
Don't get too carried away. We know how that ends up.. lol
Indy510
#74
Post by Indy510 »
Yeah, that's why I named this car "another one bites the dust" .... :lol: ... but this was over a year ago, when I had the patch:
Indy510
#75
Post by Indy510 »
Got a set of wagon leafs from Tendril, so I used a bigger leaf as the flipped one:
Indy510
#76
Post by Indy510 »
finally low enough:
#77
Sweet jesus. that thing is low :rof: How does it ride?
Ni10
#78
Post by Ni10 »
izzo wrote:Sweet jesus. that thing is low :rof: How does it ride?
can Indy get it out of the drive way ?
When you get into the 710, is it like falling on the ground, mofo is low.
nice
Indy510
#79
Post by Indy510 »
It could "maybe" get out of the garage .. if I had enough 2x6 planks ... :lol: ... the 5" blocks put the shock mounts lower than the tires:
#80
I didn't want to be negative, but I thought that 5 inches of blocks was to much.
4 inch blocks is about it for a 521 truck, with them one really needs to use aftermarket rims to get the clearance needed in case of a flat using 510 wagon shock mounts.
To me it looks like 3 inch blocks is about the max for you, perhaps you can find or have made de-arched leafs, I cannot see your rear shackle mount, maybe some mods can be made there to lower it like I did to my 520 project.
These are roadster shackle mounts that I bolted to the frame, it's around a 4 inch drop at the shackle, but it around a 3 inch drop at the axle itself, I would never use these on a truck that was for hauling weight, but as a looker it has been fine so far.
Here is the difference on the truck with a tape measure.
