Bratmobile aka slick willy
Re: Bratmobile aka slick willy
I kinda do. In my experience they are better for MPG and driveability on a stock engine. Personally, I think Webers are overrated. They will run pretty okay on most engines. I just think the Hitachi is a better choice for your car. My 1200 used to occasionally get dirt in the jets. I'd pull the top plug, blow them out, back on the road. Wasn't the carb's fault I had a rusty fuel tank. I even put an A14 Hitachi on the J15 in my brother's 520 and it ran great.
I would agree, Webers are over rated, but they have there place, Mike said when I bought the NL320 from him that he should have converted over to a Weber a long time ago, he was nice enough to change it over to a Weber clone before I took possession of the truck, he said it drove way better.
I am bias here, I hate all downdrafts in general, they are a pain in the ass as far as I am concerned, they have cost me large sums of money over the last 4 years, and I cannot adjust them to save my ass, but I can adjust dual SU side drafts in serviceable condition no problem, I can even adjust out of spec carbs to where they run alright, I have a questionable set on the work truck, but they run alright, so I leave them alone.
I have 5 vehicles with SU carbs right now.
- Has thanked: 1 time
- Been thanked: 2 times
They did not. All were A12, A14, or A15.wayno wrote:I heard that some 210s had L20b engines, so that is why I mentioned I had one, didn't know what engine you had.
Pretty easy to put one in though...
Stuck in the 70s...
FWIW, the 1200 carb with the 210 jets in it is a great carb for an A14/A15.Jamee wrote:It's official, the Hitachi is being rebuilt.
A lot simpler than the 210 carb and almost indestructible.
Stuck in the 70s...
- K_trip
- Cars: DATSUN
67 Bluebird R16/5spd
71 510 Goon L16/4spd
Nothing wrong with that approach.Jamee wrote:It's official, the Hitachi is being rebuilt.
I rebuilt the stock carb on my 510 and it has been running so much better ever since.
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
Check your throttle shaft for play before you go to far.
- jayden71
- Title: Bewb Captain
- Cars: '71 Viagra blue 521
Indeed, never neglect the shaft
- Jamee
- Title: Fluffer
- Cars: 1977 Datsun B210
- Has thanked: 3 times
- Been thanked: 10 times
Carburetor is all cleaned and beautiful...start putting it back together and look at that, this piece doesn't fit. *lil research* they sold us a rebuild kit for a fucking 620. Now we wait again for the right kit. Should be here tomorrow.
On a side note we replaced ALL the vacuum and fuel line hoses. (Under the hood.)
- K_trip
- Cars: DATSUN
I'm sure you'll get it, with a little patience.Jamee wrote:...start putting it back together and look at that, this piece doesn't fit.
On my carb rebuild I used emery paper on a piece of glass to get the gasket surfaces flat, things got wonky over time. I also had to helicoil a few holes that were stripped. I'm happy to have the stock carb on my 510, but some folks don't want to spend the time - they prefer to throw a Weber at it.
- Jamee
- Title: Fluffer
"Clunk.....clunk" you say? Yep. Time for:
Ball joints
Outer wheel bearings
Inner wheel bearings
Inner wheel seals
And brakes.
Ball joints
Inner wheel seals
And brakes.
^^All fixed?^^Jamee wrote:"Clunk.....clunk" you say? Yep. Time for:
Ball joints
Inner wheel seals
And brakes.
- Jamee
- Title: Fluffer
No. I've got some health issues going on and things keep coming up that take precedence. I don't want to over burden Walt. Hes already taking such good care of me.
