the mine now coupe.
RedBanner
Title: MasterBlaster
Has thanked: 2 times
Been thanked: 2 times
Re: the mine now coupe.
#481
Post by RedBanner »
Yes. Had to modify them some. Wich is not great, but ill get another set and see if they work without serius "adjustments.
RedBanner
#482
Post by RedBanner »
Did way better on fuel on the.way to the beach, was into the throttle the whole way and used 3/8 of a tank.
RedBanner
#483
Post by RedBanner »
Alright, lol, so this is weird, all coincidence, im not smart enough to think this far into the future.
I swapped gears, swappped tranies, im running a taller than stock tire. My speedo is dead on.
#484
RedBanner » Fri Aug 01, 2014 7:09 pm wrote:Alright, lol, so this is weird, all coincidence, im not smart enough to think this far into the future.
Woah.
#485
Witch doctor.
#486
Datsun Gods approved of your work.
You were rewarded with perfect speed.
Don't abuse it.
RedBanner
#487
Post by RedBanner »
"Do you know how fast you where going" the officer ask while he inserted a fresh tazer battery
"..... yes, I do" he admitted honestly,
#488
RedBanner » Fri Aug 01, 2014 9:09 pm wrote:"Do you know how fast you where going" the officer ask while he inserted a fresh tazer battery
:| lol did you get pulled over?
RedBanner
#489
Post by RedBanner »
Nope.
RedBanner
#490
Post by RedBanner »
So, I filled up thursday morning, got home last night with almost 3/8 of a tank, I was fully prepared to get much worse gas mileage switching from that old webber and a 1200 to a 1.4 with su carbs... but I actualy think im getting better mileage. Did not expect that.
#491
That's pretty damn good mileage.
RedBanner
#492
Post by RedBanner »
Ill fill it up and get some numbers when shes dry, but in contrast, I usually fillup before I leave the peninsula, or at the latest westport. Yesterday I planned on stopping at westport, but was just over half a tank, decided to keep goin.
#493
Ever have a shake from the mini mart there? Omnomnom.
#494
RedBanner » Mon Aug 04, 2014 8:12 am wrote: I was fully prepared to get much worse gas mileage switching from that old webber and a 1200 to a 1.4 with su carbs... but I actualy think im getting better mileage. Did not expect that.
Not too surprising. Webers aren't famous for their fuel economy. IMO they only make a decent upgrade compared to a worn out or otherwise fucked up Hitachi. SUs are just great carbs.
RedBanner
#495
Post by RedBanner »
True, It was doing pretty good for a weber, if I.cleaned and tuned itbbefore a long trip. Untill it shit its guts out at least.
#496
Completely agree Jess. Webers are just alright, good aftermarket support, and people tend to like them, but yea... SUs are probably the closest thing to EFI that not EFI.
RedBanner
#497
Post by RedBanner »
"I got home with 3/8 of a tank"
:fry:
Getting suspicious
After I drove to the airport, then to home depot, lunch, and then home.......
:aykm:
Filling my 2 gallon gas can before I go to work tomarow, just incase.
Has thanked: 1354 times
Been thanked: 236 times
#498
#499
Last night I got home from work on Empty, like left turns dived the needle under the line, and right turns brought it back above. Today, the car had a good needle width between empty and the needle.
But yes, be suspicious.
RedBanner
#500
Post by RedBanner »
Bwaaaahahahahaha
Its always worked perfect, but I did upgrade to a 50amp ir alt (+20ish amps lololol)
Maybe its causin some weirdness. Maybe ill just fill it up and see what it will hold at this point. Anything more than 5 gallons would be suspect as hell.
