So, who knows something about driveshaft lengths?
Are 4sped 4door shafts the same as 4spd wagon shafts?
510 Driveshaft length - goon vs 4 door
- levigideon
- Cars: 72 510 Wagon
Re: 510 Driveshaft length - goon vs 4 door
510 4 speed 26.1"
5 speed long tail is 31.5
Drive shaft will have to be shortened 5.4 inches if you use a wagon drive shaft with a 5 speed long tail in a wagon.
The stock 2dr and 4dr sedan driveshaft is 42 & 9/16th or 42.5625"
The stock goon is 48 & 7/8ths or 48.875
The shortened goon driveshaft for a 71b longtail should be 43.475"
The difference between a properly shortened wagon drive shaft and a stock sedan drive shaft is .09125" difference.
less than an inch difference. so, if you wanna make a 510 wagon a long tail 5 speed, find a sedan drive shaft. or use a dogleg transmission and you won't need to dick with drive shafts. It can be done, and has been many o times already.
There's your lesson for the day
- levigideon
Thank you. So we'll have to source a wagon shaft or have one made. It's going into a wagon with a 4 speed, and the only driveshaft we have a line on right now is a 4 door shaft.
Oh, my bad. Thought you were putting a long tail in a wagon. Either way, guess it answered that
- levigideon
Yep!izzo wrote:Oh, my bad. Thought you were putting a long tail in a wagon. Either way, guess it answered that
Nobody knows about this project yet...
- datsunmike
^^^ the man I learned this drive shaft info from
- levigideon
Interesting...
Thanks for the photo mike! Gives a better picture of things in my head. (pun intended)
