Instrument Panel/dash Cluster Voltage Regulator (Fuel/temp)
Gray
Has thanked: 18 times
Been thanked: 25 times
Post by Gray »
Sorry no longer available! I'll update if I do another run of these.
Instrument panel voltage regulator. Will fit 68-69 510. Will also fit 311/411/520/521.
Sold state part that replaces the mechanical voltage regulator for the fuel and temp gauges. So if you have a roadster or early pickup or 510 with flaky or misreading temp and fuel gauges this may be a part to replace.
Direct plug in. Red wire is 12V+ in. White wire is 9V+ out to gauges. Ring terminal is 12V- (ground) and screws to the back of the gauge cluster.
$15 shipped in the US. Paypal address is: dguy210(at)gmail(dot)com
The original part looks like a small metal box on the back of the cluster (68 510).
From the side you can see the male spade connectors and ring terminal (right of photo).
How the replacement part plugs in. This can be replaced on the 510 without pulling the dash or cluster. I don't know for the roadster or pickups if this is also true but probably.
On the left is the old part on the right is the new one plugged in. Leads are left a bit long to make it easier to plug in to the dash cluster without pulling the cluster.
Note: this is also posted on Ratsun, but due to the dumbass way the classifieds work no one ever sees it.
Email is dguy210(at)gmail(dot)com
aka Dguy210
w1sterling
Cars: roadster
Re: Instrument Panel/dash Cluster Voltage Regulator (Fuel/te
Post by w1sterling »
Hi, I would like to order one to be used on my 1967.5 datsun roadster 1600. Stock is a bi metallic puting out an average pulsating 8 volts.
Does it sound like it will work?
Wayne Sterling
wsterling@sterling-agency.com
Did you come up with this fix yourself? Pretty ingenious.
Pretty awesome!
Also looks like we have a new guy that joined to buy your part. Even better!!!
Gray
Post by Gray »
w1sterling wrote:Hi, I would like to order one to be used on my 1967.5 datsun roadster 1600. Stock is a bi metallic puting out an average pulsating 8 volts.
Wayne Sterling
Yes it should work, the 65-67.5 stock regulator has a slightly different mounting from the 510 pictured but is electrically identical. I believe your current regulator should look like the one below.
flatcat19 wrote:Did you come up with this fix yourself? Pretty ingenious.
It is based on a how-to someone posted a long time ago, I cleaned up the design and with Ranman72's help did some beta testing. He's been running one in his 510 for a while now.
aka Dguy210
Charlie69
Cars: 1966 520
1985 720 King Cab ST
Post by Charlie69 »
Hi just wondering where my voltage regulator is?
Charlie69 wrote:Hi just wondering where my voltage regulator is?
See the rectangular can on the right above the speedo housing on your instrument cluster in your photo, that is your voltage regulator for your gauges.
Charlie69
Cars: 1966 520
Post by Charlie69 »
Hi Wayno , I meant the one of these I purchased. Hey that is the cluster I modded for the 1980 Harnes. LOL
I received the regulator today in the mail thank you.
Charlie69 wrote:Hi Wayno , I meant the one of these I purchased. Hey that is the cluster I modded for the 1980 Harnes. LOL
Yes that is your instrument cluster. :lol:
Gray
#10
Post by Gray »
Please note, it appears the 510 1969 RHD KMh instrument cluster may not use this voltage regulator. See the pics below, the circuit on the back looks very similar as does the cluster itself, but the mounting point for the voltage regulator is not present. If anyone has any other info on this I'd be interested to know. This cluster is a JDM KMh cluster so it may have other differences too.
Front:
Back:
See the previous post, it would normally use one of the contacts on the back of the brown cover there (fuel gauge). I'm wondering if this was a late model thing which had it built into the fuel gauge as on some of the other models.
aka Dguy210
lobo
Cars: 72 datsun 521
#11
Post by lobo »
Do you still have these for sale
