Crystal. My first pos.
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Re: Crystal. My first pos.
That 2 door is running a 185/45/15. 14s are getting harder to find that small, but, a 185 60 would fit better, a 175 60 would have alittle stretch, might help. All depends on what sizes you can find.
is it not possible for the tires that I'm running now to be able to tuck or something of the sort?
I don't really want to tuck but the rear coilovers get pretty low and don't go too high :/
Please explain to me how you intend to tuck your current tires... Basically camber.
just try it and see what it looks like
I'll see what happens.Laecaon wrote:Please explain to me how you intend to tuck your current tires... Basically camber.
Thanks anyways.
Damn, I guess I'll have to blow more money on tires :/
I'll def try and see what happens.
Anyways, here's a pic of the carbs I'm buying.
He said although sittin 3 years, it all ruins smoothly and nothing is stuck.
I hope he's true.
random guy off ratsun.
They look like 510 smog carbs with deletion plates.
I have never had a set with that vacuum idle control.
They might be fine, they might be crap, it kinda depends on who is selling them, and if they good stuff or crap.
Is dirttrack510 selling these?
Just because they are smog carbs doesn't mean anything, there is no difference if serviceable.
Will the vacuum idle control mean much?wayno wrote:They look like 510 smog carbs with deletion plates.
I was hoping to get to learn when i put these in because i learn hands on. lol.
and it's mrdr.pepper selling them.
$250 shipped.
Thanks for the help man.
That's why I considered it.flatcat19 wrote:That's a good price.
Guy seems nice and all but then again... you know.
I'm prayin it works out.
If you have any disposable money, go for it, but 3 years is a long time to be on a shelf.
They look basically complete, you will need a dual choke cable, and they are expensive unless you fab up a used Z car one out of a wrecking yard.
As I said, none of my dual SU setups have that vacuum idle control, and I have no issues.
Do you need a choker cable because I'm not running one on my car atm.wayno wrote:If you have any disposable money, go for it, but 3 years is a long time to be on a shelf.
So is the idle control a plus? Well from the name, it seems to be if it's an idle control . lol
I'm gonna go for it. wish me luck man.
Mine will not start without a choke cable, and these are special choke cables, they have two cables operated by one knob.datmo wrote:Do you need a choker cable because I'm not running one on my car atm.wayno wrote:If you have any disposable money, go for it, but 3 years is a long time to be on a shelf.
Look at this link, it is a generic cable, and it's $150.00
http://www.datsunparts.com/1805
Here is another link to all the cables.
http://www.datsunparts.com/Cables
fuck man. time to reconsider.wayno wrote:Mine will not start without a choke cable, and these are special choke cables, they have two cables operated by one knob.datmo wrote:Do you need a choker cable because I'm not running one on my car atm.wayno wrote:If you have any disposable money, go for it, but 3 years is a long time to be on a shelf.
Look at this link, it is a generic cable, and it's $150.00![]()
Even with that $150 cable... lolflatcat19 wrote:Just get 'em.
Cheaper than side webers anyday!
do you know if you NEED the choker?
Shit.datmo wrote:Even with that $150 cable... lolflatcat19 wrote:Just get 'em.
The guy just replied and told me i need the choker...
You can make Zcar cables work, you just have to fab up an interior mount, you can likely get one for less than $20.00 from a wrecking yard if you can find one.
I also have thought about making a choke setup that will work with a single choke cable, you just have to fab some linkage up to make it work.
Jacob doesn't use a choke as far as I know, but he maybe is running his carbs richer, fact is I don't know how he gets it started, but it does start, because I see him driving it.
I'll have to ask him.wayno wrote:You can make Zcar cables work, you just have to fab up an interior mount, you can likely get one for less than $20.00 from a wrecking yard if you can find one.
Once again, the worst part is not being near a damn yard...
For an interior mount, I can just use where my push to start is. or just make a hole and do it nicely somewhere.
Either way, this is still a buy in my opinion. If it goes well, even better.
I'm just hoping.
My old choker cable was broken. lol
Zcar choke cables for the dual SUs are not like roadster cables, Zcar cables are more like old 10 speed bike shifter levers, and I believe they are mounted in the center console of the Zcars, not on the dash.
They work like a lawn mower speed control, all the way forward is fast, all the way back is off.
Oh fuck, that's kinda weird.wayno wrote:Zcar choke cables for the dual SUs are not like roadster cables, Zcar cables are more like old 10 speed bike shifter levers, and I believe they are mounted in the center console of the Zcars, not on the dash.
Well luckiy, I know a guy running mikunis and he;'s not using a choker and he said he's more than positive i'll be fine.
He's in norcal. and socal an't any colder.
I've never seen snow since I've lived here. lol
