Browns 86 4x4 dailey beater
Re: Browns 86 4x4 dailey beater
Yeah I'm trying to..... Stupid thing is still over heating. Need to come up with some extra cash to put a radiator in it by this weekend. But I don't get payed till the day of leaving for the trip. I don't trust the truck on trails with it running hot like this. *sigh..... I will figure it out. Not missing out on this trip. Lol
Thats the spirit Brandon
This is getting real old Datsun..... Came out to a puddle under my t-case. Lol
I like that
Yeah i i was pretty excited. I just happemed upon it and was like "gasp!!!!"
PS. It wasn't me that did the hack wiring job
Wiring gets patched correctly. Unless its a stereo install, then don't look under the dash at the spaghetti ball
Good job on the truck dude. I never pulled the air cleaner on the weber!! Re-tune the air/fuel mixture after its hot, and re-time it. Since I didn't know it was out of whack, I tuned it with the choke closed apparently. Probably why it lacked in power, and ate gas like a mother fucker. Good catch!
I tuned the dizzy by ear, then took it for a spin and the pinging was almost gone... so a good tune is in need!! BTW, pull the dizzy cap and remove the white wire unless I did that already. It will make it so both spark plugs fire at the same time instead of only at certain points. It will burn clean across the cylinder that way. Also, these DON'T get timed to 10-12 like an L series, 5 degrees BTDC is tits.
Yeah I have it set up at 5* btdc. I will look into this white wire thing. I know it needs a tune up. It's on the list lol. New plugs, wires, rotor and cap are all in store in the next couple weeks. But on today's list
Picked up a radiator, 180* t-stat and gasket. Yes, yes I know it's not a brass rad. But it will do just fine. Intact it's thicker then the stock brass. If this doesn't get this bitch running at a normal operating temp I will be pissed lol. Only thing left then is to replace the fan it self and find a fan shroud. But it only really ever runs hot on the freeway so the shroud and fan prolly are not the issue. Anyways, I will get that bitch in later today prolly.
A rad doesnt need to be brass. I had a new alum platic one in my sikver st. Thing worked too good lol.
Oh I know this. I have encountered Datsun peeps who shake their head at me and my aluminum core radiators. I think they do fine.
New thing to fix!!!!!!
Upper control arm bushings on the driver side are completely hammered out. Guess it's a good reason to get aftermarket upper arms that provide 3" of lift
dang... What a shame...
4x4parts.com iirc. Has nunch of nissan stuff even 720
Got the new tires on
also put on what I call "the hobo canopy" pics shortly after I finish clearancing the fenders some. I think the canopy may only be temp. I sort of want to find one that fits a little better. The hobo canopy is a couple inches to long out the back.
Brown wrote:Got the new tires onalso put on what I call "the hobo canopy" pics shortly after I finish clearancing the fenders some. I think the canopy may only be temp. I sort of want to find one that fits a little better. The hobo canopy is a couple inches to long out the back.
I have one off a 620. it same color as the truck, would match.
Canopies are dope for camping trips man
It fit the 620 width/length wise http://nwdatsuns.com/viewtopic.php?f=21&t=423
Well that's a little bit of a downer. Just found out my driver side floor pan is rotted out. Lame sauce....
Is fixable tho?
It is. Would be a pain so idk if ima bother. It's around the cab mount and where the floor meets the firewall. Oh wells. Just Datsun liven haha.
That area can be pita.
If it doesnt have some rust,is it a Datsun?
I'm going to crank up the torsion bars a little more to gain a little more clearance. But here is some pics.
