Waynos parts for sale thread
- Has thanked: 401 times
- Been thanked: 1242 times
OK I changed the name of this thread, and deleted the tanks for sale as they have all been either cut in half to scrap, or I am keeping a couple to try and make a couple kingcab tanks as the ones I have now dragged the ground at some point and caved them in, so I am going to try and weld the top half of a kingcab tank to the bottom half of a good longbed tank.
Anyway here is what is for sale.
I have an L16 short block, I bought the engine for the dual SU package it had on it, the guy said it ran, but I didn't want to set up an engine stand to see if it actually ran, as I will never use an L16 block in a vehicle.
It looks good, the head gasket looked great, I am asking $40.00 for the block.
It looks good, there is not really much of a ridge at the top of the cylinders at all, it turns freely, it's actually one of the best looking L16s I have ever pulled apart.
Next is the 210 head off the L16 block, I suspect that it is good as the guy said it ran before he pulled it out of the truck, I am asking $40.00 for the head also.
It has the U20 cam.
Next up is the Z series exhaust manifold, it is not cracked, I am asking $20.00 for it.
Next is the head, I believe it is a Z22 head, it looks like all the head bolts are there, the valve cover goes with it, I am asking $40.00 for the head/valve cover.
The valve cover.
I will start another post.
It has the U20 cam.
The valve cover.
Re: Waynos parts for sale thread
Here is a W58 closed chamber head, it is missing a bunch of parts, all but 2 exhaust valves are there, I want $20.00 for it.
I don't know a lot about the next item other than it turns freely, it was not connected but the belt was still turning it, it comes with all the hardware to mount it, I searched it on ebay and could only find a rebuilt one for a 510/520(521?), it didn't look like this one, if I were selling this in CA it likely would be worth something, but around here folks were throwing them away, I have only seen a couple of them.
Next is a very dirty alternator, I expect it is externally regulated, I also think it was rebuilt because of the sticker, asking $10.00 with all the mount hardware.
I have a L16 flywheel(200mm), it is what it is, $10.00 with all the mount bolts.
Here is a 521 exhaust manifold with head pipe, it has the smog tubes welded shut, although when I deleted them I used brass plugs on mine, lets start at $40.00 or reasonable offer.
Here is another one with all the smog tubes, this one has been sitting around for a while, it doesn't have the head pipe.
This is just the start, I have a lot of stuff that is going to be for sale, I will put this stuff on craigslist in a few days or so, I will likely put more on here tomorrow.
There was a guy on the realm looking for a 200mm 5 bolt(they are pretty hard to find now )
wayno, you are giving this stuff away!
- draker
I'd be interested in the closed W58 and the compressor. Looks like the head has been milled at least once. Do you see cam tower spacers?
- Justinberni
- Cars: 1986 720
I just looked at it, yes it appears to have been milled, no I don't see any shims but my eyes are not what they used to be, and I don't want to remove the cam towers to find out for sure either.draker » Mon Jan 04, 2016 9:12 pm wrote:I'd be interested in the closed W58 and the compressor. Looks like the head has been milled at least once. Do you see cam tower spacers?
Here is a photo of the front cam tower.
Are you talking about the air compressor?
Left or right side, what finish(black/chrome)?Justinberni » Mon Jan 04, 2016 9:18 pm wrote:Do you by chance have a corner light for 84+ 720?
I also have two Datsun Roadster 4 speeds for sale, I am asking $50.00 each for them right now.
I don't have any shift levers.
- Justinberni
- Cars: 1986 720
- draker
Air compressor.
How soon do you want these gone? I'll buy both.
And watching for other stuff you post.
I can sit on them for a while, but I do want to get them out of here.draker » Mon Jan 04, 2016 9:55 pm wrote:Air compressor.
As I said, the compressor just keeps pumping more and more air into the tank, I was lucky I was standing there watching the pressure, as I wanted it to stop but it wouldn't, so I pulled the air release till it was where I wanted it to be and turned it off/flipped the switch.
- draker
That's fine with me as long as the pump and motor are good.wayno » Mon Jan 04, 2016 10:15 pm wrote:I can sit on them for a while, but I do want to get them out of here.draker » Mon Jan 04, 2016 9:55 pm wrote:Air compressor.
- draker
I will try to get up there ASAP. Ideally I could make it up within the next two weeks. Pay now or cash when I arrive? I'm fine with either.
Cash when you arrive, I will put the head with the compressor.draker » Mon Jan 04, 2016 10:37 pm wrote:I will try to get up there ASAP. Ideally I could make it up within the next two weeks. Pay now or cash when I arrive? I'm fine with either.
I will send you a PM with my phone number, call when you plan to come to get it.
So, does anyone have the measurement for the 520 driveline from u-joint to u-joint?
Also does anyone have the measurement for the 510 wagon driveline from u-joint to u-joint?
I have a set of front half shafts for a 1980 Datsun 720 4X4, these had fresh lube/grease in them when I removed them, they looked new back then.
I am asking $40.00 for the pair, I heard that these will fit other years if they are reversed, meaning right side on the left, ect.
I have the manual locking hubs also, $20.00 for the pair.
Anyone have interest in these Weber carbs, they are both 32/34 DFT 9A/11A, Make offer!
I also have this Solex side draft carb, it is likely for parts only, it is missing the floats for sure, I will keep it if I cannot get anything for it, as I have a manifold/Weber in my stash that looks exactly like this, I am fairly sure this will bolt onto the manifold also, maybe this can be rebuilt, but maybe it's not worth it either.
Are any of these worth $5.00?
The far right one says Redline on it.
I have a couple longshaft 4 speeds out back without a front case on them, both have the speedo drive in the rear case, I would take $20.00 for each of them, I will even help put the front case on if you have one, but you have to have everything to put it together, case, cover, and front bearing.
I have a complete Z20S engine, I seen it run for a while before it was pulled from the what I recall was a 1981 Datsun 510 Wagon, it has been stored in my shed since I bought it, I had to take it to get the 2 short shaft 5 speeds that the guy was selling as a package, it ran good as I recall, I would like $150.00 with my word it runs or your money back, if I have to set it up to run it, I will likely want more.
- Has thanked: 1165 times
- Been thanked: 1136 times
I can't use a single thing you have but your prices are outstanding. GLWS.
The far left carb adapter,does it have TD on it?
If so is a trans dapt 2107
510freak » Tue Jan 05, 2016 8:49 pm wrote:The far left carb adapter,does it have TD on it?
I can find no markings on it, but when I looked up the number, mine doesn't look anything like that one.
I did have one of them around here at one time, but I don't know where it is anymore.
I have a few other adapters around here, they look to be Weber adapters.
The two adapters on the right(middle/right) are a Redline set I think.
I have a lot of shit around here I have collected when I was going to the wrecking yards every weekend before Schnitzer bought out all the U-pull-it yards around here and raised all the prices, I used to have a yearly pass every year until they were bought out, everything changed after they were bought out.
