I had purchased (2) of them (one for a back up as I found one I "thought" I liked better).
Apparently both were .6 inches to short of the actual one I needed.... except.... the part numbers check out
Bro ordered one up , came out , whipped another new one on in about 1-minute at most from the top.
I was shocked... I'm only out a couple of clams , but very happy that was all the problem "was".
Engine runs really well still as of today.
I leaned in and broke a vacuum elbow line off the air-box , and replaced that. Doh !
Vacuum tree seems to be in good shape.
Engine power is GREAT/smooth.
Drives well.
No smoke and plenty of exhaust flow.
Transmission shifted good in "economy" mode. Haven't tried "sport" or "winter" mode yet.
Car drives really quite well.
Passengers cv joint has a very very.. light clunk on one or two left turns (this is the big long cv-joint with the bearing bolted to the engine btw lol).
All signals work well , brake lights , radio code is plugged in working , etc.
Check engine light is on as of the moment , but I had several things going back + forth when starting/running the car.
Will probably read , and clear/cycle/drive here soon.
Obviously has to get through DEQ.
009 by 71240z, on Flickr
010 by 71240z, on Flickrbumper cover is roughed a little bit.. meh.
007 by 71240z, on Flickr
006 by 71240z, on FlickrI just let it sit and idle for a bit while checking on it.
Raised the rpms here or there (1,500 or so).
Engine temp was very steady.
Lifters were all very quiet , and can/could only really here the injectors operating
This is after driving it home.
Video --- https://www.flickr.com/gp/blue73/428V42
That's pretty much close to the end of updates for the car for now or unless I break something lol.
