Redemption? flatcat's 521
Re: Redemption? flatcat's 521
#421
Well, at least it's doing something.
#422
It will get used properly in the near future.
#423
Snow shovel. Put a snow shovel on it.
#424
Oh and as far as the yellow inner lights, I got mine off of an old Merc from pull-a-part for about $4 each. If you go that route as opposed to LED. But you probably already knew that you could use those.
#425
We don't the have any old stuff around here like that. If we did I'd go find an old e30 and use all 4 of those lights.
New Wagner yellows are like $10 all over the place. Although, Mercedes yellows would be nicer.
#426
My brother used Mercedes on the Backwoods 521.
#427
I promised work...here is so.e of what I am doing...
I scored a really nice Grant GT wheel from eBay a while back...
Got it cheap. Because of this...
Time to fix that.
I will let that sit for a day or two and do the final sand and paint to the wheel.
#428
Also...After pondering what I wanted to do with my headlights.
I originally wanted H4 outers with yellow middles to use as DRLs.
After what Jacob said, archaic lights vs. more modern, I think I'll look at something different.
H4 outers, and H1 inners for high beams...Housings made by the same manufacturer.
Question though...Do the outers get a high beam signal when the highs turn on?
If they did, and the high beam on the H4 activated at the same time as the inners I would need to only do the pin-out swap to make everything work.
#429
510 factory is like that (lows turn off), high is all four. I think the 521 is the same.
#430
K. That will be the route I take then.
For now...Steering wheel fix. Garage clean up/modifications.
Next...Dash removal/electrical repairs. Steering wheel mounting. Modification to pedals.
Next, next...Engine removal/5 speed swap.
#431
Welp...
There is a gap or two created by the Gorilla Glue expanding. I'll get back to this thing another time and full those gaps.
For now, very impressed for a cheap fix. After I fill in the gaps I'll paint the spaces and gaps with some black Testors.
Cheers!
#432
You cannot even see that side when your driving.
#433
More reason to never use Gorilla Glue. I only will use it on ugly things.
E6000 is probably the adhesive I would have used.
#434
I asked tons of people. The only consistent reply was Gorilla Glue.
I asked a handful of interior guys-all said GG.
I'm fine with the turnout. $30 wheel, $3 repair.
#435
#436
#437
Liked
#438
What!?! a not HF cherry picker?
#439
It's Kevin's hoist. I have no clue. I don't own one myself.
I did use my HF aluminum 2 ton Jack and some HF Jack stands.
HF 27mm socket for the crank bolt.
#440
That whole process deserves a like button.
