wheels/tyres
LUIS COLCHETE
- Cars: DATSUN B110, NISSAN SUNNY
LUIS COLCHETE
Re: wheels/tyres
What do you think
http://www.ebay.co.uk/itm/ULTRALITE-CLA ... 35cf83d6ba
13*6 +10
or i ve searching for 13*6 +6
Many thanks
Miguel
13*6 +10
Many thanks
Miguel
LUIS COLCHETE
Re: wheels/tyres
i will looking for my brake caliper..
13*6 +8 its your and the brake caliper touch the whell
13*6 +10 will touch the whell more
13*6 6 dont touch the whell or touch a liltle bit
Im reason?
Im reason?
Re: wheels/tyres
Sorry. Critical misprint,. I ment +18, +23 is for a stock 12x4 inch wheel.
Re: wheels/tyres
And it may take a small grind with some pads, ive ran these wheels before without having to grind the caliper at all.and after the.pads are broke in they.seem.to have plenty clearence, my point was even if you bolt a wheel on that seems to fit, take the fact the caliper moves into consideration.
Re: wheels/tyres
Ah, lets start this over, your stock wheels should be 12x4 +30. Wich is about 3.75 back spacing. If you stick with a wheel that has close to 3.75" backspacing you should be fine. So that translates to a 13x6 inch wheel to a +12 or +15 (did the math in my head, and estamated a few things that are common but could be different on every set of wheels) so my +18 wheels rubbed with new pads. The stock tire is 570mm, a 175 60 13 is 240mm on a 5 inch wide wheel, so that should be great.
Re: wheels/tyres
There we go. Little more clear?
Re: wheels/tyres
What country are you in? Im in the us, and my brakes are slightly different than uk, african ones. But same as aus, or aus b210.
LUIS COLCHETE
Re: wheels/tyres
HI
I ve two set of 12" whells:
The original one 12*4 (Tyres 155/70)
The alloy whells 12 175/70 tyres (this whells touch the brake caliper that i ve cut it)
im From Portugal city of Lisbon, you are correct the stock whells have 12*4 +30, i dont measure the backspace but i ill and must be 3.75.
Ok, let me me know if i understand:
So if i found a new whell 13*6 offset beteween from +12 to +15 which represents a backspace 3.75 i can use 175/60 tires
and i have no problem and they dont touch the brake caliper. If touch i had cuted it.
Many thanks
I will see on ebay something with this measures
Luis Colchete
Many thanks
Luis Colchete
LUIS COLCHETE
Re: wheels/tyres
I will see on ebay, and buy them but i cant fail the measures
Thank you very much for your replies
LUIS COLCHETE
Re: wheels/tyres
Hi
Sorry for disturb
I thin they fit please see the link and say your opinion
http://www.midlandwheels.com/Shop/P-766 ... -ET16.html
Many thanks
Luis
Sorry for disturb
Many thanks
Luis
LUIS COLCHETE
Re: wheels/tyres
or this one but ill to choose the offset
http://www.midlandwheels.com/Shop/P-226 ... -Over.html
Many thanks
Luis
Many thanks
Luis
Re: wheels/tyres
LUIS COLCHETE wrote:Hi
Sorry for disturb
Many thanks
Luis
Luis, I would have to say these will fit, esspecualy after hearing you shave the caliper already. The tires my rub the foot well on full lock turning, and you may need to sligtly roll the inner fender lip.
Have you lowered your car? If so there me be some slight rubbing, but nothing you couldnt take care of yourself with verry little effort.
With all the little tiny variables in parts from country to country, you may have a little more, orlittle less rubbing than an american car would. Just cant be 100 percent sure of anything without getting the tape measure out, and doing a little math.
If you had a rim with no wheel, you could measure clearence from that wheel. Thats really the only way tp be 100 percent certian
LUIS COLCHETE
Re: wheels/tyres
ok
Many thanks
Next weekend i will take measures, in order to ask some informations with seller about the whells that i show.
I will post my future whells
Luis
Many thanks
Luis
LUIS COLCHETE
Re: wheels/tyres
Hi
I take the measures chassis offset of my Datsun 1200 2 Dr sedan, and i have:
face measure 60mm
back measure: 109mm
with this measurements i can use 13*6 whells 175/60 tyres offset +23mm
6"=152.40
centerline 152.40/2= 76.20
76.20+23=99.20
76.20-23=53.20
face measure 60-53.20=6.80 clearance between fender and whell
back measure 109-76.20= 32.80 clearance between wheell and coil
+18 mm offset
76.20-18=58.20
76.20+18=94.20
face measure 60-58.20=1.80mm
back measure 109-94.20=14.80
Please inform me if i am thinking wright? I can use +18 and +23mm offset?
I will take bettet the measures...
Many thanks
Miguel
face measure 60mm
back measure: 109mm
6"=152.40
76.20+23=99.20
76.20-23=53.20
+18 mm offset
76.20-18=58.20
76.20+18=94.20
Many thanks
Miguel
Re: wheels/tyres
Thats what im running, but like I said I had to gring almost a 1/4 inch off the caliper.
LUIS COLCHETE
Re: wheels/tyres
Hi
Anybody knows the official measures for Datsun 1200 front chassis offset.
According with some opinions whells 13*6
OFFSETS from +8mm to 18mm fits Datsun 1200 with no problem but i want choose +18mm without problems. (i ve cutted a litle the height caliper)
I made my measures and they fit, but i could make an measure error but next weekend i ill make another time
http://i297.photobucket.com/albums/mm21 ... easure.png
Many thanks
Luis
Many thanks
Luis
Re: wheels/tyres
