Re: dual carbs
Posted: Fri Oct 11, 2013 8:54 pm
Ask converted to datsuns. He has those.
i cant find his name. lol ill look moreLaecaon wrote:Ask converted to datsuns. He has those.
Perfect.Laecaon wrote:http://nwdatsuns.com/memberlist.php?mod ... ofile&u=96
http://www.napaonline.com/Catalog/Catal ... 0300383082Laecaon wrote:napa... its just a manifold gasket...
shows how much of a nub i am. lolConverted_to_datsun wrote:No... You have to put the year and model of your car to find the right ones...
to tune the carbs, I found this off ratsun...Converted_to_datsun wrote:Ok now you're cooking! Haha that one will work
As I said, there are as many ways to adjust these carbs as there are people with them, my post above is a general decription on how to adjust them, you have to fill the carbs with the proper oil, the float levels need to be the same, but since the guy said it was on a running engine, then I see no reason to rebuild them before trying to start them, I repeat, do not touch the needles mounted in the plunger for any reason, you can bend them by picking them up off a desk.datmo wrote:to tune the carbs, I found this off ratsun...Converted_to_datsun wrote:Ok now you're cooking! Haha that one will work
http://www.teglerizer.com/sucarbs/techtip6.htm
I gotta read this thing more.
i wish they had tuning su's for dummys though. hahah.
I'm excited to get my swap done.
Then i can get my swap and matchbox dizzy swap done the coming weekend.
get my license monday and then get my rear coilovers the next weekend. haha
wayno wrote:As I said, there are as many ways to adjust these carbs as there are people with them, my post above is a general decription on how to adjust them, you have to fill the carbs with the proper oil, the float levels need to be the same, but since the guy said it was on a running engine, then I see no reason to rebuild them before trying to start them, I repeat, do not touch the needles mounted in the plunger for any reason, you can bend them by picking them up off a desk.datmo wrote:to tune the carbs, I found this off ratsun...Converted_to_datsun wrote:Ok now you're cooking! Haha that one will work
I won't be using a choke since I'm never really in areas that cold.datsunmike wrote:Well this is quite a lot to bite off and chew. Installing a manifold and tune for running not one but two unknown SUs?
Do you have the choke cables with these?
Are the slides free to move?
Damper oil?
I see they have at least been de-smogged. What's the history on these? What were they run on?
If the engine has been sitting over night...you're probably going to need choke cables to fire it up.datmo wrote:I won't be using a choke since I'm never really in areas that cold.datsunmike wrote:Well this is quite a lot to bite off and chew. Installing a manifold and tune for running not one but two unknown SUs?
Damper oil?
Everythign is free to move.
What's sketchy is they've been sitting for 3 years but came off a guys 510.
