Page 59 of 66
Re: soon to be LZ2.3 521 :)
Posted: Mon Oct 06, 2014 1:15 pm
by uberkevin
WRONG AGAIN... still leaking oil with the 521 yoke in..
i mean it doesn't have a driveline attached to it.
Posted: Mon Oct 06, 2014 1:16 pm
by uberkevin
Posted: Mon Oct 06, 2014 1:19 pm
by uberkevin
That's the seal I picked up at napa.
It's gotta be the seal!
I've asked for a 83 720 seal and an 85 both didn't work.
Posted: Mon Oct 06, 2014 1:20 pm
by uberkevin
The
by uberkevin
The other part number.
Posted: Mon Oct 06, 2014 1:37 pm
by uberkevin
Looking back to find the year of my trans it's a 85.
I looked up both part numbers. I should be fine.
That means it's the transmission doesn't it?
Hm.
Posted: Mon Oct 06, 2014 3:21 pm
by uberkevin
Posted: Mon Oct 06, 2014 3:56 pm
Well there is definitely something spraying all over everything, and that is without a driveline connected, the seal isn't working, as that 521 yoke has a plug in the hole, correct?
Posted: Mon Oct 06, 2014 4:01 pm
by uberkevin
Yep. There a plug in there forsure.
The seal is clearly not working I agree. But wtf! Haha
Posted: Mon Oct 06, 2014 4:06 pm
The transmission vent is clear, correct?, you didn't plug it for any reason, correct?
Posted: Mon Oct 06, 2014 4:11 pm
by uberkevin
Vent?
Posted: Mon Oct 06, 2014 4:12 pm
by uberkevin
Didn't plug anything so me not know what the vent is doesn't really matter.
Posted: Mon Oct 06, 2014 4:22 pm
On the shortshaft it is located on the pancake between the alloy front and rear cases.
It's just a tube bent 90 degrees.
If it's leaking on the 521 yoke also, try another seal with a different part number, I heard there were 2 or 3 different ones.
Posted: Mon Oct 06, 2014 4:27 pm
Posted: Mon Oct 06, 2014 4:28 pm
by uberkevin
Above you can see the two I used. Two different seals, I'll get another new one and see if it's different as well.
If it's just the transmission then I really am fucked!
I guess I can drop It and change it out if I had another like it but it took me a while to even find that one. I guess I could get a Z car trans can't i?
Posted: Mon Oct 06, 2014 4:29 pm
by uberkevin
Yeah that tube. I wondered what that was. No not plugged. Still bent in a 90 just like that.
Posted: Mon Oct 06, 2014 4:34 pm
When the seal is out, find a good light, and inspect that tailshaft, look for anything that looks like a crack, I hope for you it is just the seal being wrong.
Posted: Mon Oct 06, 2014 5:20 pm
by uberkevin
Posted: Mon Oct 06, 2014 5:21 pm
by uberkevin
You see the split? Crack whatever you wanna call it?
Posted: Mon Oct 06, 2014 5:22 pm
by uberkevin
