LZ23 engine build
- Has thanked: 403 times
- Been thanked: 1243 times
Re: LZ23 engine build
What I have in it is working, so I will measure it again and figure it out, I have quite a few oil pans around here, one of them will work, if not then I will use the one in there now, just won't be perdy.flatcat19 wrote:Wouldn't you need a 720 L20B pan?
Oh yea, the ARP stud kit came today, Yea!
- Has thanked: 1309 times
- Been thanked: 219 times
I messed up and posted in the wrong thread, I will save this spot for my next post.
- Has thanked: 145 times
- Been thanked: 644 times
By the way, this LZ23 engine is still sitting in the same exact spot it was a month ago.
