720 4x4 rear end info
Post by izzo » Tue Jul 22, 2014 7:53 pm
Any of you nw guys have a 720 4x4 rear end. Mines getting bad. No howling noises but serious play and clanks when shiftin dem gears. I want the whole axle. Idk how to swap gears or if that would fix it.
As always. Cheaper the better. Sooner than later.
Changed to info thread.
Re: wtb 720 4x4 rear end
Post by izzo » Thu Jul 24, 2014 10:58 am
bump
Has thanked: 1187 times
Been thanked: 1156 times
Post by DRIVEN » Fri Jul 25, 2014 4:11 am
Has thanked: 413 times
Been thanked: 1263 times
Post by wayno » Fri Jul 25, 2014 3:32 pm
It really depends on the year and what it actually wrong with your rearend, the first 3 or 4 years used the H190 rearend, that one is easy to change out the gears, but if it is an 80 4X4 720 you have, you could possibly have them 459 gears, good luck finding them.
The later 720s had the C200 rearend, not easy to change out them gears unless you know how.
Do you know your gearing izzo?
Post by izzo » Sat Jul 26, 2014 2:26 pm
wayno » Fri Jul 25, 2014 4:32 pm wrote:It really depends on the year and what it actually wrong with your rearend, the first 3 or 4 years used the H190 rearend, that one is easy to change out the gears, but if it is an 80 4X4 720 you have, you could possibly have them 459 gears, good luck finding them.
I don't. I looked at the tag and I thought it said 41 but i will have to double check.
I have that guys cell number for the brown 4x4. I bought his roll bar and tow package from him. If i had a few more bucks I'd get that 4x4 and make it a fun wheeling machine. I'll lowball the fucker and offer 100 cash.
Post by wayno » Sat Jul 26, 2014 2:47 pm
I have a 1980 720 that I made a diesel, the 1980 tag doesn't have the rear gearing stamped on it, they look like my tag in the photo below.
!981 models on had the ratio on the tag in the bottom right corner, 4.1 was a common ratio, unfortunately my 4.1 is sloppy, and I could not in good conscience give/sell it to anyone, I thought my rearend was going bad recently, turned out to be a bad "U" joint.
Post by izzo » Sat Jul 26, 2014 3:42 pm
I thought it was a U joint also. I got under there and the only play was when i spun the rear drive shaft. it was floppy at the pumpkin :\ I can hear it clank when I'm driving. Can also hear it over bumps clanking around. I'll take a video at some point and show you.
That's the spot where I checked. I will take a pic and post it sometime, maybe tonight. At work at the moment.
Post by wayno » Sat Jul 26, 2014 10:56 pm
izzo » Sat Jul 26, 2014 4:42 pm wrote:I thought it was a U joint also. I got under there and the only play was when i spun the rear drive shaft. it was floppy at the pumpkin :\ I can hear it clank when I'm driving. Can also hear it over bumps clanking around. I'll take a video at some point and show you.
I could not tell my U-joint was bad till I removed the driveline, then it was easy to tell, that was the clang I would get when I stepped on the gas or let off the gas, I also thought it was the rearend, I even pulled the fill plug to check to see if it had any fluid, it did have fluid, and it was the correct color also, that was when I went back to the driveline and pulled it, the rear u-joint was bad, but it looked good in position.
Pull the upper fill plug in your rearend, stick your finger in the fluid inside and check the level and color, if you have no fluid, it's likely bad, if the fluid color is silver or brown, it's likely bad, if it is amber/clear yellow, then the rearend is not likely the issue, it doesn't take that long to check, if it is black, then you will need to drain it to check the magnet, if it has chunks of metal stuck to it, well you know what the issue likely is.
Post by Laecaon » Sat Jul 26, 2014 11:35 pm
Yea I don't think rear ends clank. They more of clunk. Ujoints clank because of hollow driveshaft.
#10
Post by wayno » Sun Jul 27, 2014 8:02 am
Laecaon » Sun Jul 27, 2014 12:35 am wrote:Yea I don't think rear ends clank. They more of clunk. Ujoints clank because of hollow driveshaft.
It can "clang" when the rearend is bad also, remember that C200 dually rearend issue I was having, the first time I lost one of them the driveline was like a tuned instrument, it was loud, and it turned out to be the carrier housing inside the rearend that had ovaled holes.
The driveline had a hell of a tune going on, not sure why for sure, but I think it was because it was solid(good u-joints) and very long(2 feet longer), so the next time another one(rearend) started making the same noise I figured it was the same thing, it wasn't as loud yet, but it kinda sounded the same, well that one turned out to be a u-joint that time, the funny thing is that I just assumed it was the same issue, and instead of pulling the rear cover and inspecting it, I just repaired the first rearend and changed out the whole rearend, and then it made the very same noise once it was in, I had not inspected the driveline I had just bolted it back up, I pulled the cover off the one I had just removed and seen it had no issues, so that was when I pulled the whole driveline and found the problem, I am very good at wasting my own time, and other peoples time to if you took the time to read this. :lol:
You are correct though about how stuff usually sounds on H190 rearends, when they go bad, they usually howl or make a clunk sound, I have went through about 3 of them(all H190s), all of them howled, but one clunked also.
#11
Post by izzo » Sun Jul 27, 2014 3:08 pm
Yeah, mine doesn't really make a noise. but it does vibrate on decell or when i left off the gas.. It's probably the same thing. no video yet been to busy.
I am positive its the rear end/axle already. I checked all the u joints. I left it in gear and shook/turned everything. the member has play in it. Shameless self bump, too. I fear its getting worse.
Has thanked: 665 times
Been thanked: 243 times
#12
Post by BLUE » Tue Jul 29, 2014 9:29 pm
For what value this may present itself as.
I've had 2 rigs that had dis-integrated u-joints that showed no play what so-ever.
They were dry as a bone , and ground to dust on one cup at least that I remember.
I decided to pull out the driveline , and press them out since I knew the rear differential as a whole was good on one of them (serviced/repaired/re-sealed).
I believe I replaced with greaseable u-joints , and pretended everything would be ok after that *sucking thumb*
Sure enough a-ok after.
Thought it would be worth mentioning , but alas I really don't know.
I'm not a pro or even close :D :rofl:
Hope you get it figured out Tim !
Free bump as well for ya
#13
Post by izzo » Wed Jul 30, 2014 8:40 am
I as well thought it was a U joint. It had the clunk of a bad one, and when i decell it makes that vibrating noise. Maybe it is??? I am off work today so I will get a video of the rear end.
#14
Post by wayno » Wed Jul 30, 2014 1:23 pm
izzo » Wed Jul 30, 2014 9:40 am wrote:I as well thought it was a U joint. It had the clunk of a bad one, and when i decell it makes that vibrating noise. Maybe it is??? I am off work today so I will get a video of the rear end.
To check U-joints, you need to take the driveline out of the truck, it has to be almost falling out to see it when it is in the truck, my work truck started vibrating a month or so ago, I thought it was the rearend also as it was clanging, but it was the U-joint, and I could not tell till I dropped the driveline, I was lucky, it was the rear one, so I didn't have to remove the whole thing, it's a 521.
I have had a few rearends go out, all the H190s howled, even though they had lots of play in the pinion flange, they did not clunk/clang, they just howled, now the C200 rearend is a different story, I have had them do all sorts of shit, that doesn't mean it is not your rearend that is going bad though.
When I buy a rearend from the wrecking yards, I look for ones that have less than a sixteenth inch play, I will take up to an eighth inch play, anything more and I pass on it.
Did you ever look at the color of the gear oil by removing the fill plug and sticking your finger in the hole and into the fluid?
#15
Post by Laecaon » Wed Jul 30, 2014 2:15 pm
My goons ujoints went out. Though you couldnt tell in car, or out of car. But every start in first gear and then into 2nd was a clang. But yea no slop even out of the car...
#16
Post by izzo » Thu Jul 31, 2014 9:25 am
I'll check the fluid. I didn't take a video. I'll get dressed here soon and go take that video.
Most times I can tell a bad u joint by grabbing the drive line and moving it, shaking it, etc... Not always tho. But usually if they are bad enough to make that noise they will move in some sort of way.
#17
Post by izzo » Thu Jul 31, 2014 10:06 am
So, it looks like there is a little play in the video, but I assure you there is none in the U joints. It's just the angle. I can grab the yoke and hold it, spin jerk twist the driveline (giggity) and notta... I also used a pry bar and tried to see if that would make any movement. Notta!
The truck is in neutral. I have a wheel chalk on a wheel and the E-Brake on. That's the play... That's the clank... There is a super super tiny bit of play between the back half and the front half. So small I can't measure it with tools I have, very very small.
Video is processing, but here is the link.. Should be done soon.
#18
Post by Laecaon » Thu Jul 31, 2014 11:46 am
C200 have back covers right? Remove the cover, look from crap. See none. Replace Ujoints. Like I said, just because there is no play doesnt mean its not ujoints.
#19
Post by izzo » Thu Jul 31, 2014 11:49 am
did you see the video? you can see the yokes moving and clanking...
This does have a back cover. I will not remove it till i have a new gasket and some fluid for it... Tomorrow if i have an extra 30 bones I will replace both U joints, but I bet my last dollar it's the same result.
#20
Post by DRIVEN » Thu Jul 31, 2014 11:50 am
I don't see a link.
