Country slice
Has thanked: 665 times
Been thanked: 243 times
Re: Country slice
#121
Post by BLUE » Sun Mar 19, 2023 8:51 pm
Yes ! 100% agreed ! None of this BS cooling fan modules or alternator clutch pulleys designed to extend the life of a $12-$15 belt.
Yet another scam/Garbage
Re: Country slice
#122
Post by BLUE » Sun Mar 26, 2023 3:42 pm
Nobody gives a fling post update. New aisin water pump/thermostat into wifes daily. Probably wont be touching these recent replaced parts again.
Re: Country slice
#123
Post by BLUE » Sat Aug 26, 2023 11:36 pm
Not much of anything , just a repair. Typical home stuff.
Noticed some bubbling of water/air between an expansion joint. Looked at the valves/pipes next go the home. Those weren’t it.
Re: Country slice
#124
Post by BLUE » Sat Aug 26, 2023 11:37 pm
Got a tool or two delivered
Result ? Apparently this joint was the culprit. Got lucky.
The tool worked pretty decently especially considering doing aggregate. The 3.5 gallon (small) water pressure bottle for the wet cut D blade saved the day.
The existing compression coupler ? Yeah...literally tightened up the nuts , and it stopped leaking. Ordered more parts (locally didn't have anything).
Has thanked: 1187 times
Been thanked: 1156 times
Re: Country slice
#125
Post by DRIVEN » Sun Aug 27, 2023 5:48 am
Definitely could have been worse.
Re: Country slice
#126
Post by BLUE » Sun Aug 27, 2023 6:29 pm
110% luck of placement , and type of leak. Feeling fortunate
Has thanked: 1320 times
Been thanked: 222 times
Re: Country slice
#127
Post by Taterhead » Thu Aug 31, 2023 4:56 pm
So lucky!! Good job getting it fixed
