soon to be LZ2.3 521 :)
Re: soon to be LZ2.3 521 :)
#921
uberkevin » Wed Aug 20, 2014 10:43 pm wrote:You can see the bolt is a little more further forward then where it normally would be. But as you can see I didn't make a new hole I more extended the old one so the Trans would still sit where I need it too... well ill see in a few days when I get the block in.
So basically the mount needs to be slightly shorter than what it is.
The way I made the mount, the holes in the mount cannot be elongated, the overkill bracing I do just lets the 720 mount bolt in, from the looks of it, you need a mount that is another half inch back(guess).
uberkevin
#922
Post by uberkevin »
I'm almost there man just need a few more full days..
I think we just got approved for a house in oly.. truly find out tomorrow. So that's some stress and time that gets freed up. If or when we get approved we can move in sometime after the 5th I believe..
Every day after work I get home at about 7 and work in the garage tell about 1030 11. Take a hit and hit the hay.
uberkevin
#923
Post by uberkevin »
And that's so the drive line would bolt up right?
Either way I think the holes that I may end up drilling will bring it back to where the drive line will bolt up. Let just hope it's not to far back however I don't think that will be a problem. Again.. we all will see soon.
#924
Yes that would be so the driveline would bolt right up, and so that the transmission would not need drilled, but it will need a custom mount designed differently than what I make, but mine are custom also, that plate that is angled up likely could be deleted and have the mount still work fine, but I build everything strong, my welding is not that great, so I over build everything so it will not matter.
uberkevin
#925
Post by uberkevin »
I've got a few good ideas for my old mount. If I end up changing this one. But this o e is fine. Like you said you build them strong, this forsure looks strong.
I hope I remember to paint the mount.
Welding isn't that bad. I've been doing a little. Well did a little right before I left for oly for a few days.
I have no faith in my welds at all. Or if you could even call them welds. Wayno your welds look pretty darn good. Something I think will last a long while.
Oh and thanks a lot for the mount..
uberkevin
#926
Post by uberkevin »
Bottom end is together.. Oil pan on. Everything torqued down to spec.
I think I'll be putting the head on tonight, I'm cleaning the old gasket off of it right now.. I cut the front off the gaskets as well to prepare.. things are coming together nicely. I'm getting g better.
uberkevin
#927
Post by uberkevin »
Got some work done! Not done yet, I've got a few little things before it's done and ready for the clutch and tranny. I thought this chain and sprocket kit was relatively new I maay just get a new one. Ha
uberkevin
#928
Post by uberkevin »
#929
Mmm motors omnomnomonm.
Clean your thermostat housing yo! hahah
uberkevin
#930
Post by uberkevin »
Oh yeah!! I'll be cleaning it up real nice.
Well as nice as I can.
#931
Hint, that is perfectly acceptable for a timing chain setup. The deal is, The V can be anywhere on the Notch. You actually have better overlap than most I have seen. I would just run that.
uberkevin
#932
Post by uberkevin »
Glad someone said something about the chain timing. I thought it looked fine but it's always good to know someone else thinks so.. it took me a minute to get I was forgetting to twist the cam a little forward so I can get the bright link where it should be. It wouldn't reach... I was stating to get upset haha
uberkevin
#933
Post by uberkevin »
look right?
So I've been thinking about how I'm going to put oil in the motor and oil cooler. Should I just fill up the oil cooler? Then the hoses and try to screw the hoses on. Or is there a way I SHOULD fill her up?
uberkevin
#934
Post by uberkevin »
Oh and that oil drive is off a little huh should be just about inline with the two holes huh. Before 30 not after.
#935
looks fine to me. shrug i think if you move it back a tooth it will be to far back.
#936
uberkevin » Sun Aug 24, 2014 12:48 pm wrote:Image
look right?
The angle looks good, I just cannot remember if the fat or thin side is supposed to be towards the radiator. :lol:
uberkevin
#937
Post by uberkevin »
:rofl: :rofl: Hahaha
Yeah I said the same thing after I put the oil pump on.
Thanks though I kept thinking it was off.
I need to pick up the cherry picker and get the block off the stand so I can get the rear plug in before I forget. Also need to put the clutch and tranny on.
Oh and then you guys know what time it is.. :) I'll try to get it in.. but! I've been going slow. Don't want to fuck shit up. Gotta do more little things too. Clean tape the paint ha and just lot of little things.
#938
Flat sides are good. Its not at 12 so that is also good. But tend to like the line to be a little more inline with the mounting holes. Its fine though, especially with everyone mismatching pedestals and dizzies.
uberkevin
#939
Post by uberkevin »
Had to stop.. cherry picker is fucked!! Bent or some shit. With engine in the air it leans to the right, lifting in the air in the rear left. Couldn't move it by myself had to get two people to help put it on the tires. I forsure didn't want to bolt the trans on with the picker not doing its job... I'll rent one tomorrow... If I can get off work early to get it... any who that's it for now. Hope I can get this bitch in tomorrow.
#940
Why don't you own one yet? They aren't that much -- especially used, and you'll use it over and over for the rest of your life.
