Adam's annoying ass green 620
Too bad gas tanks aren't like ping pong balls.. toss a dented one into some boiling water and voila!
- Spoona_Jay21
- Cars: 1978 620 KC
why wouldn't it work? fill it 3/4 of the way full with water, if it has a good sealing cap put that on, and make sure to plug all the other lines reeal good, and let it boil. eventually enough pressure would build up and it should pop.MicroMachinery wrote:Too bad gas tanks aren't like ping pong balls.. toss a dented one into some boiling water and voila!
Talkin out my ass, and it is only theory, but it never hurts to try.
You'd probably have to weld it up to get that good of a seal.Spoona_Jay21 wrote:why wouldn't it work? fill it 3/4 of the way full with water, if it has a good sealing cap put that on, and make sure to plug all the other lines reeal good, and let it boil. eventually enough pressure would build up and it should pop.MicroMachinery wrote:Too bad gas tanks aren't like ping pong balls.. toss a dented one into some boiling water and voila!
- Spoona_Jay21
- Cars: 1978 620 KC
MicroMachinery wrote:You'd probably have to weld it up to get that good of a seal.Spoona_Jay21 wrote:why wouldn't it work? fill it 3/4 of the way full with water, if it has a good sealing cap put that on, and make sure to plug all the other lines reeal good, and let it boil. eventually enough pressure would build up and it should pop.MicroMachinery wrote:Too bad gas tanks aren't like ping pong balls.. toss a dented one into some boiling water and voila!
I can see that. as said, just a theory.
- Eagle_Adam
too late guys, its already installed and im over it
or so i keep telling myself
- Eagle_Adam
Hory shet dude. That's ..... fuck i don't even know what to say. Do like, do want.
- Eagle_Adam
These went in the rear
And these went in the front
Took these out
Next up:
Finish the centerlink flip
Took these out
Next up:
Are you flipping the link?
Should fit the 240sx pan that way? At least that is what I have read.
Progression kicks ass!
- Eagle_Adam
flatcat19 wrote:Are you flipping the link?
yup, gotta fill in the holes for the centerlink and reverse the taper to clear the oil pan
- Eagle_Adam
and it looks like the last piece of powder-coating is done!!!
hopefully i can wrap up the front end tonight, then its will be the goons turn in the garage for the weekend
- Eagle_Adam
Thought those were rod bearings when I scrolled down the page.
- Eagle_Adam
- Eagle_Adam
yes........ yes it is!
- Eagle_Adam
and this is what it held
well thanx for lunch.....
but this is what i really wanted, and boy is it yummy!
lower timing cover to match the block
crank pulley
oil pan to complete the black bottom end
silver upper timing cover to match the cyl head
water pump pulley
valve cover
motor mounts
and last but not least, a set of grill trim rings!!
crank pulley
water pump pulley
valve cover
motor mounts
