A couple things I don't see mentioned in any swap guides... If you use 620 rubber motor mounts with stock 240sx upper brackets, you will have to do something about the "locator pin" or whatever you want to call it on the rubber insulator. The notch in the 240sx bracket isn't notched far enough to allow the 620 pin to go in. I ground the pin off the rubber insulator. In hindsight, I should have notched the bracket a bit (about 1/8th" or maybe 1/4th").
There are two brackets that tie the trans to the KA motor, each has four bolts, two go in the block and the other two go in the trans. The very bottom bolt on the left side is awfully close to the steering center link. I may remove that one bolt if it looks like it needs it next time I'm under there.
The lower Rad hose will be tricky, the flex hose you see in some swaps won't work without a 90 degree elbow in the mix (at the outlet of the rad most likely).
Annnnd, a question. To get things going, can I use 5/16th" hose to replace all the old hose, looking now and all the old rubber is 3/8th". How will it do if I use the stock hard lines with my 5/16th" hose?
Bonus picture:
