and so concludes this fun filled thursday...
got alot done today..
like expected, i got the brakelines, tierods and a set of shocks. got a set of tierods off a d21 and they were too long and had a weird bend in em that hit the frame. i went back and swapped em out for another set from an 85 4x4 720. right on the money with the 720 ones. they have a turnbuckle type of adjuster instead of the sleeve clamp the others had..
got the brake lines from another 85 720 in the yard. they work great.
got the shocks from a wd21 style pathfinder. dont know what year, but it was a v6 model.
the tierods need to be tightened up, but i have a baseline toe adjustment set. 56 1/4in on the backside tread and 56 3/4in on the frontside. its easy to push back and forth. we'll see how it does...
heres a couple pics of the buttoned up driver side.
shocks are mounted and final, gonna get the tierods finished with cotter pins...
last but not least....
the brakes work!
the pile of junk works! got the brake bled this evening, and while only rolling it in the garage, they feel like theyre gonna work great!
pedal has about a half inch of soft modulation area, and then firms up just right. still need to drive it and see if they "really" work, but i think i got it!
last things to do are change the oil and filter, get a piece of aluminum pipe for my upper radiator hose, fill it up with coolant and see it i can get it running with the new coil.
more to come!
