New 720, 1985
Re: New 720, 1985
Like I said, if its too big, the lower rad hose will push the alt down, and then the alt and you are danger close to the pitman arm. But you can run a ZX water inlet to cure this.
The 200sx (79 or so) is the only Small Bodied Internally regulated alternator by Nissan/Datsun.
Also, all the L and Z series alts should swap and use the same electrical plugs. And if you change 1 plug you can use KA/SR/CA/VG alts (and maybe change the pulley). My 80amp is actually a CA18DET alternator.
- Justinberni
- Cars: 1986 720
Re: New 720, 1985
I'm gonna get the 200sx alt and if it doesn't fit I'll go get a ZX inlet from pick n pull..
I'm gonna be working on the 620 all this week, but no build thread of pictures yet. I'm not showing it until it's worthy, so a week or two. There will be before and after pictures though.
Stay tuned
Stay tuned
Re: New 720, 1985
Every build thread should start with before pics. No time like the present.
Re: New 720, 1985
Nissan used to make the adapter changer. From T plug to whatever the KA uses. Tho I just use Male/female spade connectors and two 2" wires so I don't have to cut the original plug.
Maybe it wasn't nissan who made them. I have one stashed away.
- Justinberni
- Cars: 1986 720
Re: New 720, 1985
I'll have before pictures, just won't show them until the same time I show the after pictures.DRIVEN » Mon Nov 24, 2014 6:30 pm wrote:Every build thread should start with before pics. No time like the present.
Re: New 720, 1985
Don't fix it if it's not broke, if the 620 alternator is charging, leave it alone.
I believe that Laecaon is talking about the idler arm being in the way, but it seems like the 79 620 shouldn't have that issue.
Re: New 720, 1985
^^Wisdom^^wayno » Mon Nov 24, 2014 8:08 pm wrote:Don't fix it if it's not broke, if the 620 alternator is charging, leave it alone.
- Ni10
- Has thanked: 119 times
- Been thanked: 24 times
Re: New 720, 1985
he posted a big load of them. SEE VVVVDRIVEN » Mon Nov 24, 2014 6:30 pm wrote:Every build thread should start with before pics. No time like the present.
Re: New 720, 1985
Man. Some stock gauges would really pimp that thing out. Clock,tach,oil and volt meter. Cheap at any junk yard. Over priced at any classified ad
- Justinberni
- Cars: 1986 720
Re: New 720, 1985
Id need the center consol if I want the oil&volt gauges for the 720, and people want like 80 bucks for the consol so fuck that.
I'm not sure if I'm trading for that 620 now, I like the 720 so much
Re: New 720, 1985
I was talking about the 620. There's too damn many Datsuns in one threadNi10 » Tue Nov 25, 2014 9:56 am wrote:he posted a big load of them. SEE VVVVDRIVEN » Mon Nov 24, 2014 6:30 pm wrote:Every build thread should start with before pics. No time like the present.
- Justinberni
- Cars: 1986 720
Re: New 720, 1985
Here's too before and after pictures of my truck today, a friend helped me detail it, we waxed and polished it, and some other shit that I don't remember, but I'm so happy with how it turned out, the paint use to be so flat and dull on the bed, looks so much better now.
