If only it wasnt a grant hub. Stupid 5 bolt pattern.flatcat19 wrote:datmo wrote:I'm really hoping to find a damn 620 hub.
http://www.grantproducts.com/products/a ... 5/25/467/1
1979 kc named Lulu
Re: 1979 kc named Lulu
I already tried but like the nrg hub, the spline part won't pass the threads that ab olt screws on to.Laecaon wrote:Idea, see if your 510 and your 620 match splines.
well thankfully the place i bought the hub form let me return it after some conversation for full price so I'll just buy a 620 boss hub off ebay.
It'll take awhile but I still have work to do too.
My 620 dash bezel also broke today when putting in my radio. was kind of really disappointed.
I wasn't even using much force and half the thing popped off.
I think it comes off from removing the gauges in the back but 'I didn't have enough time to play with it.
I got my radio into the spot but I still need to wire and put in my speakers.
i was thinking rustoleum's seafoam green for the color.
Everyone breaks their dash bezel. Everyone. There really should be a PSA about how not to break it.
Lol that makes it a bit better. I wanna paint it or make it unique.Laecaon wrote:Everyone breaks their dash bezel. Everyone. There really should be a PSA about how not to break it.
I also got my lip today. Its the camaro lip. I think it looks badfucking ass. Ill figure out how to mount it sunday.
havent been on this shit for awhile but painted winter grey and did not turn out too nice but looks really mean.
I'm gonna repaint it some day for fun. Enjoyed it plenty and picked up some diamond steelies that are 16x8 and fit well.
pics!
interior is more stickered up. this thing's a rat and i love it.
the door is just dirty in this pic..
pics!
I like the overspray on the tires.
lol i was thinking of your dime when i wrote that
Thanks!Taterhead wrote:Personally I like the grey better than blue.
I wanna spray it a nice cherry red or something. I think it'd look good.
I bought some nicer fitting diamonds. I got rid of those old rollersizzo wrote:I like the overspray on the tires.
having issues. the truck is stuttering pretty bad.
I replaced my fuel pump and i had a water leak so i replaced that too but nothing....
any ideas?
any ideas?
Clogged jet, hole in fuel line letting air get sucked in, water in tank, fuel tank could need cleaned. I'd guess fuel, could be spark...
Pull rotor and check contacts n see what they look like, check plugs too, they new? Use NGK nothing else.
new ngk plugs.izzo wrote:Clogged jet, hole in fuel line letting air get sucked in, water in tank, fuel tank could need cleaned. I'd guess fuel, could be spark...
new lines. maybe a cleaned fuel tank?
i checked all i know.
if you are un sure of fuel tank, run a line to gas can. problem is if it did by chance suck shit up theres a chance there is crap floating in bottom of bowl... hard call man... did you rev it out a bit and see if it went away?
check your choke too
yes i did and the car seemed the same.izzo wrote:if you are un sure of fuel tank, run a line to gas can. problem is if it did by chance suck shit up theres a chance there is crap floating in bottom of bowl... hard call man... did you rev it out a bit and see if it went away?
it seems to drive alright but first is still having stuttering issues.
double check your wiring on the matchbox dizzy. make sure spark isnt able to jump somewhere... make sure you have a ground going from the spade on the matchbox side near the vac advance too. i heard missing those could cause issues. Take some effnig photos of what you have going on so we can seeeeee
will do wed since that's the next day i have off to work on the truck.izzo wrote:double check your wiring on the matchbox dizzy. make sure spark isnt able to jump somewhere... make sure you have a ground going from the spade on the matchbox side near the vac advance too. i heard missing those could cause issues. Take some effnig photos of what you have going on so we can seeeeee
thanks in advance
Is it sporadic or constant? Only when getting on it or when idling also?
Sounds like water in the gas to me. Run it empty and see.
