Rory's 72 510
67411sss
Cars: 1974 620
1972 510
Rory's 72 510
Post by 67411sss »
Had this for a while, found it on a orchard locally
I was trying to sell her to help buy a 2 door 510 but that fell through:(
And why I'm selling the 620, it is an auto with no rust but has some electrical hurdles
Pics,
It's a project for sure but another Datsun saved is a good thing.
My problem right now is figuring out the ignition I spent some time tonight on the wiring and now have power to the starter and spark to the coil (when cranking) so hopefully getting closer to being able to turn the key and have her start.
I still don't have power to the dash?
Tonight I hooked these wires to the ignition switch after combing wiring diagrams
It's going to be a slow project this one.
Re: Rory's 72 510
What's up with the hood corners?
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
Post by 67411sss »
Used to have a deer guard mounted on the front with arms that slid up the corners through the hood and bolt to the body
Got to love previous owners and their mods
Re: Rory's 72 510
It's nothing another hood won't fix, but it's to bad, it ruined what looks like a good hood.
Re: Rory's 72 510
It's got a lot of good things going for it. Like most "saved" Datsuns, it seems most of the work is going to be undoing what the previous owners have done to it. I see it has a hitch too. Just can't imagine towing ANYTHING with an automatic backed L16 :rofl: .
Re: Rory's 72 510
Nice save on this one.
dislexicdime
Re: Rory's 72 510
Post by dislexicdime »
better get that Factory sound deadener of the floor before it rotts it out
kittens and bj's
Re: Rory's 72 510
Nice score man. I rikey!
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
Post by 67411sss »
Not bad for $400 :)
Re: Rory's 72 510
#10
Score for $400 :fyea:
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
#11
Post by 67411sss »
Lets not forget I did buy it without a title and had to track down the brother of the old owner and convince him to sign the car over. Perseverance pays off!!!
Re: Rory's 72 510
#12
:thumbs:
It does too Rory!
K_trip
Cars: DATSUN
67 Bluebird R16/5spd
71 510 Goon L16/4spd
74 Li'l Hustler L16/4spd
Re: Rory's 72 510
#13
Post by K_trip »
Nice save!
Thank goodness the electrical on these things is pretty simple, I'm sure you'll get it sorted out in no time. That trunk lock and modified hood is a crack up, but we've all seen worse. It doesn't look like it's been wrecked, and unless it's got a lot of miles on it - I think there is a lot of life left in this one.
It cleaned up nicely :)
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
#14
Post by 67411sss »
Got spark at the sparkplugs, I smell fuel but she won't fire. Maybe a bad carb I couldn't see fuel coming from the nozzle, fuel pump works. Might be ignition or carb oh what fun !! :fuu:
Ni10
Has thanked: 119 times
Been thanked: 24 times
Re: Rory's 72 510
#15
Post by Ni10 »
try drizzling some gas down the carb and choke it. If it start for a little while, prob the metering screws need a good douche.
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
#16
Post by 67411sss »
Yeah, tried that still nothing. I got the carb off a friend and can't verify that it worked when pulled so I might take the carb off the 620 , I know that one works and can then cancel that as the problem
MicroMachinery
Re: Rory's 72 510
#17
Post by MicroMachinery »
Good to see this one getting some love :)
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
#18
Post by 67411sss »
It's alive :fa:
Guess I had the leads on wrong :oops:
Sounds solid no knocks just dies after a few seconds , carb maybe? It kinda flutters when I pump the gas to keep her going.
Stoked the ignition wiring worked
67411sss
Cars: 1974 620
1972 510
Re: Rory's 72 510
#19
Post by 67411sss »
Rory 1 datsun 0
Re: Rory's 72 510
#20
67411sss wrote:It's alive :fa:
stock carb? You can check the fuel level in the eye. If its a weber, pull the top off and check. If you have a fuel filter tho in the engine bay you can see if it has gas in there. I'd suspect if its the stock carb it may just be super old and worn out. maybe fire it up and do little bursts of starting fluid down the carb to see if it stays running like so. Could also have a serious vacuum leak causing it to die.
