soon to be LZ2.3 521 :)
Re: 521 owner here
#201
While the wheels are off the ground....
Grab the wheel-not steering wheel-and give it a brisk shake left and right. Feel any clunks/looseness?
Now, top to bottom.
Top to bottom movement, you may need to put the jack under the LCA to load the suspension.
You may also need someone to hold the steering wheel while you doing your shaking.
If there are any loose parts an alignment is just a waste of money.
Re: 521 owner here
#202
uberkevin wrote:
flatcat19 wrote:Those look familiar.
I have a feeling something is loose or broke down under there.
Broken I don't think so, could be loose forsure.
With steering components-loose is broken.
Please play again.
uberkevin
Re: 521 owner here
#203
Post by uberkevin »
Didn't know we were playing.
Loose in what way? Loose where.
Edit* I didn't see the post some how...
Re: 521 owner here
#204
As he said, after a certain point loose is broken, if it moves enough to change your alignment, it is broke.
When stuff moves around, it will change the characteristics of your ride, like stepping on the brakes and having it do something that is unwanted/undesired, and lifting it off the ground doesn't help when looking for issues, as the parts move to a position that is not normal, and everything gets tight.
The alignment shop should be able to tell you everything that needs changed, then change it, take it back and they should align it, if they don't work that way, go somewhere else, that is what Les Schwab does for me, and I think it should be that way everywhere.
Re: 521 owner here
#205
Bring it to me. I'll give it a quick finger.
I'll even look at your truck too.
Not even 10 minutes worth of time.
Ni10
Has thanked: 119 times
Been thanked: 24 times
Re: 521 owner here
#206
Post by Ni10 »
take a look at the tension rod bushings also. If they are old and cracked will compress when you put on your brakes, will change the angle of the lower control arm ( force the arm backwards ) and make it pull to the left or right.
uberkevin
Re: 521 owner here
#207
Post by uberkevin »
jayden71
Title: Bewb Captain
Cars: '71 Viagra blue 521
'79 Patina KC 620
Re: 521 owner here
#208
Post by jayden71 »
uberkevin wrote:Image
FAPFAPFAPFAPFAPFAPFAPFAPFAPFAPFAPFAPFPAPFAP...................EERRRRRRMERHGERRRD!!!!
AHHHHHHHHHHHHHHHH.........
Thanks
Eagle_Adam
Re: 521 owner here
#209
Post by Eagle_Adam »
soooo clean!!!!!!!
for now :P
uberkevin
Re: 521 owner here
#210
Post by uberkevin »
The white is super nice in there! If only it would stay clean, we'll see.
Wish it was coated py jrock so it would look a bit better but I think I did a good job painting it.
uberkevin
Re: 521 owner here
#211
Post by uberkevin »
Also I found where some noise was coming from....
from this crack...
dat77sun
Cars: 1982 datsun 720
Re: 521 owner here
#212
Post by dat77sun »
damn bro the valve cover looks good!
Eagle_Adam wrote:he who drives it like he stole it, is he who fixes it like he broke it ;)
uberkevin
Re: 521 owner here
#213
Post by uberkevin »
Thanks man, maybe could have done a couple more coats.
Ive been think about painting my 521 dash white. I think if I redo the suede on the dash same color just put some treatment on it so the sun doesn't fad it again and then paint the front part of the dash white it would make the suede really pop! And it doesn't cost much to do so I man do it.
dat77sun
Re: 521 owner here
#214
Post by dat77sun »
i might even have you help me redo the dash pad in my 720, that is when i get the motor swap done
Re: 521 owner here
#215
If you put white suede on your dash top, what color would it fade to?
:troll:
uberkevin
Re: 521 owner here
#216
Post by uberkevin »
"I think if I redo the suede on the dash same color just put some treatment on it"
:boobs:
uberkevin
Re: 521 owner here
#217
Post by uberkevin »
I guess it might turn a golden yellow.
Re: 521 owner here
#218
I think the valve cover should be yellow.
uberkevin
Re: 521 owner here
#219
Post by uberkevin »
Hey it was yellow!!! I can paint the Datsun part yellow tho that would look nice.
Re: 521 owner here
#220
The deal was that the valve cover was supposed to STAY yellow.
